Re: M/T ET Street Radials, when should I replace them?
[Re: moparjoe360.4]
#1674325
09/20/14 01:35 AM
09/20/14 01:35 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Replace them when your 60 ft falls off. That's if you are talking strictly racing. If you are talking legality for the street the when you hit the wear bars it's done.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1674326
09/20/14 01:45 AM
09/20/14 01:45 AM
Posts: 4,676 On the parachute mount
n20mstr
I've personally been 8.30's with cords showing.....run them to the cords ....your experiences may vary
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#1674328
09/20/14 03:19 PM
09/20/14 03:19 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
I think I'll replace them before the cords are showing. But 8.30s is inpressive on worn out drag radials.
[Re: Triple Threat]
#1674330
09/20/14 04:59 PM
09/20/14 04:59 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Til there ain't no more rubber.
and when the cords first start to show.. it wears super duper fast...
[Re: 1967dartgt]
#1674333
09/20/14 10:32 PM
09/20/14 10:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is correct.. being you are running the ET streets I assume you run the streets... if a cop sees cords hanging out he CAN give you a ticket.. and most likely will.. and thats not talking about rain on the roads
[Re: MR_P_BODY]
#1674334
09/22/14 12:30 AM
09/22/14 12:30 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Agreed. I had mine for about 3 years, they worked exceptionally well... however, when I got to the wear bars, my 60' times went south. I have a 2nd set of rims with T/A radials for street now and bought a set of M/T slicks which I rarely use on the street that are on the 15x10 rims. I noticed small bits/chunks of rubber missing exposing the cords on the drag radials from driving on the street... uhhhh, no thanks. Whatever you do, just be safe.
[Re: Triple Threat]
#1674335
09/23/14 10:45 AM
09/23/14 10:45 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Don't replace them until you see the cords showing.
[Re: Crizila]
#1674338
09/24/14 10:02 AM
09/24/14 10:02 AM
an8sec70cuda
Major bad idea IMO. It's why tires have wear bars or depth holes. I'm sure M/T ( if he was still alive ) would shat a brick on that one. You guys that run them to the cords are - pretty brave.
It sounds crazy, but every racer I know on radials does the same thing. From my experience, once the center "tread" (the two grooves) is gone, the tire is only a little over half used up. Mine will still 60 foot consistently right up until I replace them.
[Re: moparjoe360.4]
#1674340
09/24/14 11:47 PM
09/24/14 11:47 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
I just replaced mine, they were 7 years old. They were dry rotted/cracked in the treads. Still had plenty of tread left but I didn't feel comfortable racing them like that.
For what its worth, M/T site suggests replacement after 4 years.
'71 Duster '17 Ram 1500
