How well does 134a work in 60s &70 Mopar ? #1674232
09/19/14 03:40 PM
09/19/14 03:40 PM
Slidell, La.
doctor_mopar Offline OP
Slidell, La.
How well do the old systems work with conversion? In my case I have the factory condenser and clutch fan, but compressor is Sanden and have the Airtemp add on evaporator under the dash.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: How well does 134a work in 60s &70 Mopar ? [Re: doctor_mopar] #1674233
09/19/14 03:59 PM
09/19/14 03:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It works fine but it won't be around in the future. They are already trying to ban it like they did with R12. http://r410arefrigerant.info/r134a-alternatives-in-car-ac/list.html
Re: How well does 134a work in 60s &70 Mopar ? [Re: doctor_mopar] #1674234
09/19/14 06:35 PM
09/19/14 06:35 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I've converted two completely factory systems in a '74 a body and a '72 b body and both blowed very cold and worked well. The a body is still going but the b body locked up after two Summers.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: How well does 134a work in 60s &70 Mopar ? [Re: dfsmopars] #1674235
09/19/14 08:23 PM
09/19/14 08:23 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
In my findings converted R12 systems work decent but some have trouble while sitting still. They seem to want more airflow through the condenser than the R12 units. I would suggest making sure you have a good fan/clutch with appropriate shroud. Also anything you can do to make the fan pull more air through the condenser will help. A electric pusher fan is helpful if room exists.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: How well does 134a work in 60s &70 Mopar ? [Re: stumpy] #1674236
09/19/14 11:18 PM
09/19/14 11:18 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
by future do you mean 2018? That's when the current type of refrigerants will be phased out. Also you won't get the same level of cooling if you use R134a in a R12 system.
B5 Challenger T/A
Re: How well does 134a work in 60s &70 Mopar ? [Re: KARLN] #1674237
09/19/14 11:30 PM
09/19/14 11:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you see where he changed the compressor and evaporator?
Re: How well does 134a work in 60s &70 Mopar ? [Re: doctor_mopar] #1674238
09/20/14 12:31 AM
09/20/14 12:31 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Why convert R12 can still be found...
Check around especially the swap meets, usually sells for between $15-25 per 16 oz...
I just bought several cans @ our local auto parts/tools /supplies swap meet...
Just my $0.02...
Re: How well does 134a work in 60s &70 Mopar ? [Re: Sinitro] #1674239
09/22/14 01:57 AM
09/22/14 01:57 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm running 134a without problems on stock assembly, just changing oil, seals, dryer ( or its content ), removing pressure valve from back of compressor and replaced with a temperature clutch cut off switch sensor wrapped around expansion valve, expansion valve readjusted ( or replaced )
Hoses needs to be replaced if they are worn, BUT if they are fine and were running R12 for long time they already "seasoned" enough to hold the smaller 134a molecules, doesn't need to be replaced. I just replaced when they ( still factory ones ) began to show leaks after couple of years.
I have not installed a clutch cut off switch though
( read from an old Mopar Muscle mag, and I did it on that way )
Re: How well does 134a work in 60s &70 Mopar ? [Re: NachoRT74] #1674240
09/22/14 02:24 AM
09/22/14 02:24 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
My Factory air '68 Dart had been converted to 134A when I got it. Didn't cool very well in my opinion. I switched it back to R12 and you can hang meat in there now.
Re: How well does 134a work in 60s &70 Mopar ? [Re: Sinitro] #1674241
09/22/14 03:05 AM
09/22/14 03:05 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Just my $0.02...
I agree, why convert when R12 is still easily available
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: How well does 134a work in 60s &70 Mopar ? [Re: 71yelladustr] #1674242
09/22/14 12:06 PM
09/22/14 12:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I converted my 92 D250 to 134 several years ago.
The A/C blows cold but it's nowhere near as cold as the A/C in my 72 Imperial (R12) or my 2014 200. It works for Texas but don't expect cabin temps to plummet immediately.
The truck had a problem with air flow over the condenser. When sitting still it would build up enough pressure to cause the belt to slip on the compressor. We hooked up a set of gauges and saw the high side peg the needle.
After trying a different belt, tensioner, and fan clutch I ended up sticking an 8" electric fan on the condenser and triggered it with the compressor relay. The pressures are under control and the stationary cooling improved a bit.
- Stu Harmon
Re: How well does 134a work in 60s &70 Mopar ? [Re: feets] #1674243
09/22/14 01:29 PM
09/22/14 01:29 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Sorry for the hijack, but I've been following this thread and it's piqued my interest! I have an aftermarket ac unit from Sears that was originally R12 on my 74 Challenger. It was installed in 75. My dad left me the car, and among the spare parts was a 134a conversion kit (Basically just the different hi/low port nipples.) However, he also left a small tank of R12. I believe its a 30# tank(?) that feels about 3/4 full. What would you guys do? Make the conversion and sell the R12? (Is this legal?) Or run the R12 for as long as possible? I understand I would need a different type of compressor oil?? and most likely need to put in new seals due to the age of the unit that hasn't been run for over 10 years.
Scott
Re: How well does 134a work in 60s &70 Mopar ? [Re: Scott Carl] #1674244
09/22/14 03:17 PM
09/22/14 03:17 PM
IL
furious70 Offline
furious70  Offline
IL
if you just need a top off now and again I'd stick with the R12 for sure.
Scott
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How well does 134a work in 60s &70 Mopar ? [Re: doctor_mopar] #1674245
09/22/14 03:31 PM
09/22/14 03:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
R134A sucks, all anecdotal tales to the contrary, but the OP might be committed to it because of the compressor he chose.
Re: How well does 134a work in 60s &70 Mopar ? [Re: John_Kunkel] #1674246
09/24/14 09:06 AM
09/24/14 09:06 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
In 2001 I upgraded the 69 GTX to the Classic Auto Air 134A conversion kit with the smaller Sanden compressor. It's been working great, and gets super cold. The only problems are the stock 69 blower is whimpy compared to new cars and the fill port on compressor is hard to get at.
Re: How well does 134a work in 60s &70 Mopar ? [Re: 63stabamatic] #1674247
09/25/14 12:35 PM
09/25/14 12:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Cold is a subjective term.
An A/C system that works well where 90 degree temperatures are extreme may not work well where 100 degree temperatures are the norm.
- Stu Harmon
Re: How well does 134a work in 60s &70 Mopar ? [Re: feets] #1674248
09/25/14 02:02 PM
09/25/14 02:02 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
This supports a concept I learned in the A/C section of a community college automotive program I took some years ago. We learned that we really don't cool anything. We remove heat from it. Heat is an energy that can be controlled. Hence the name "air conditioning". The guys with a bunch of letters behind their names claim that until absolute zero temp is reached; –273.15°C or –459.67°F, heat can still be removed. Living in Nebraska, the jet stream removes enough heat from my bones, but I digress.... The point I'm trying to make (and my wife will vehemently debate this ) A/C can only remove so much heat. If ambient temps are beyond what heat the system will remove, its going to seem like the system isn't working correctly.
OK, I think I'm rambling now due to caffeine deprivation....or maybe OD.
Scott
Re: How well does 134a work in 60s &70 Mopar ? [Re: feets] #1674249
09/25/14 02:59 PM
09/25/14 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's what I've been preaching for years and another issue is the amount of time it takes to cool the interior after a long heat soak. R134 is dismal at this.
Re: How well does 134a work in 60s &70 Mopar ? [Re: Scott Carl] #1674250
09/25/14 11:59 PM
09/25/14 11:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Correct.
An excellent auto A/C system will drop the temps about 30 degrees below ambient.
When you're tooling along on am 85 degree day and kick on the A/C you'll get temps in the upper 50s.
Try that on a 110 degree day and the air blows at a bone chilling 80 degrees.
Turn on the recirculating air in a car that has been baking in the sun and it'll chill that 150 degree inside air down to a balmy 120 degrees.
Good A/C is relative.
- Stu Harmon
Re: How well does 134a work in 60s &70 Mopar ? [Re: feets] #1674251
09/27/14 08:34 AM
09/27/14 08:34 AM
moparx Online content
moparx  Online Content
Correct.
and that is why fsms have performance graphs that show temperatures and pressures at specific outside temps through the interior ducts.
