How long do you run the dingle ball hone for? #1674197
09/19/14 01:42 PM
09/19/14 01:42 PM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
I know theres some that are totally anti-dingle-ball-hone-your-motor folks out there, I get it. But given the situation, this is how its getting done this time. So how long do you run the hone for in each cylinder? Or do you count strokes? Ive done it a couple different ways, always open to input.
Re: How long do you run the dingle ball hone for? [Re: Baxter61] #1674198
09/19/14 02:40 PM
09/19/14 02:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The speed determines the angle of the cross hatch,the faster you move it the steeper the angle,hone only till you see the disired pattern and the bore is clean.These hones remove very little material and should only be used to scuff or freshen a cylinder bore that has been bored and honed to true roundness by a Sunnen or similar process.
Re: How long do you run the dingle ball hone for? [Re: B G Racing] #1674199
09/19/14 02:47 PM
09/19/14 02:47 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
down and up max speed 12 times each hole
Re: How long do you run the dingle ball hone for? [Re: mcat4321] #1674200
09/19/14 03:11 PM
09/19/14 03:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Will make a difference of what grit dingle ball you use
Re: How long do you run the dingle ball hone for? [Re: MR_P_BODY] #1674201
09/19/14 03:18 PM
09/19/14 03:18 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Yes,coarse will make the hone more aggressive and the deeper.Only use it enough to clean and scuff the bore, too rough will kill the rings and keep more oil on the walls and cause poor oil control.The finer the finish the better.
Re: How long do you run the dingle ball hone for? [Re: B G Racing] #1674202
09/19/14 04:28 PM
09/19/14 04:28 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The obvious question is WHY are you honing it, or why do you think it NEEDS honed.
Monte
Re: How long do you run the dingle ball hone for? [Re: B G Racing] #1674203
09/19/14 05:47 PM
09/19/14 05:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I now... I should have said... "It will" instead
of "Will"... looks like I'm asking a question.. but
thanks
Re: How long do you run the dingle ball hone for? [Re: Baxter61] #1674204
09/20/14 02:41 PM
09/20/14 02:41 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Do it until you have a nice crosshatch pattern and stop. If it takes you more than 10 stokes to get that, you are doing something wrong.
Re: How long do you run the dingle ball hone for? [Re: Baxter61] #1674205
09/20/14 07:12 PM
09/20/14 07:12 PM
Idaho
LaRoy Engines Offline
Idaho
Call the piston ring manufacture and ask them which grit for how many strokes.
