Re: How long do you run the dingle ball hone for?
[Re: mcat4321]
#1674200
09/19/14 03:11 PM
09/19/14 03:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
down and up max speed 12 times each hole
Will make a difference of what grit dingle ball you use
[Re: MR_P_BODY]
#1674201
09/19/14 03:18 PM
09/19/14 03:18 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Yes,coarse will make the hone more aggressive and the deeper.Only use it enough to clean and scuff the bore, too rough will kill the rings and keep more oil on the walls and cause poor oil control.The finer the finish the better.
[Re: B G Racing]
#1674203
09/19/14 05:47 PM
09/19/14 05:47 PM
MR_P_BODY
Yes I now... I should have said... "It will" instead of "Will"... looks like I'm asking a question.. but thanks
