Flywheel Bolt length
#167376
12/14/08 02:13 AM
12/14/08 02:13 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Anyone know the length of flywheel attaching bolts? I need a set, and have found some applications call for a 1/2 long bolt. Doesnt seem long enough to me and I am thinking that is for an auto flex plate.
Summit shows them with a small shoulder, but doesnt give a length and they look just like the 1/2 long ones at NAPA.
Thanks, Doc.
Re: Flywheel Bolt length
[Re: NTOLERANCE]
#167377
12/14/08 02:36 AM
12/14/08 02:36 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
The issue you are having stems from GM and others referring to their automatic ringgear/flexplates as "flywheels". The ones I have here have 7/8" of thread.
Last aftermarket ones I got were found under a Pontiac application, I believe, as we couldn't find anything Mopar for these in the (I believe) Mr. Gasket catalog. If memory serves, they should actually be 7/16NF...not 1/2".
Hope that helps...
2 Demons...no, not my kids!
