Re: Engine builders, you have my sympathy
[Re: camastomcat]
#1673738
09/20/14 10:58 AM
09/20/14 10:58 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
a stock block will cost more in machine work because of the added band aids needed. That's where my frustration is seeded. But, I think I might finally have the predator ready to go
What block are you using now for your predator setup?
[Re: LSP]
#1673739
09/20/14 11:07 AM
09/20/14 11:07 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I was able to get one of the last steel hemi blocks. Guess I should have bought a wedge too.
[Re: camastomcat]
#1673740
09/20/14 01:45 PM
09/20/14 01:45 PM
LSP
Charlotte, NC
Trying to understand you then - why are you frustrated with stock blocks when you aren't using one?
[Re: LSP]
#1673741
09/20/14 02:06 PM
09/20/14 02:06 PM
Posts: 3,396 Pa
Hot 340
Pa
Its Moparts, what's to understand? If you're out of money you're a cheapskate, if you spend alot you're a snob, and if you're a regular guy you're not innovative enough and complacent.
[Re: madscientist]
#1673742
09/20/14 03:32 PM
09/20/14 03:32 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Well all I can add is WOW...It is no wonder we get what we get.
[Re: camastomcat]
#1673743
09/20/14 06:36 PM
09/20/14 06:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The point is it could be done but the blocks are over priced and hard to get and the options aren't there. It's an end user problem.
So who is at fault ? If the Mopar guys have bought up every X-block, R-block, Megablock that has been produced...and bought Every Crate Hemi that has been built.....how on earth can anyone blame them ????
OK I'm gonna try this one more time, just for sport. If the supplier produces 60 blocks, and the consumers need 70+ blocks, how many blocks does the supplier need to make to keep up with demand? And the bore needs to be 4.700 or bigger, and the stroke needs to be 5.5" or bigger, and the current block and cyl head design only allows for 4.560 bore by 5" stroke, what needs to be done to supply little Johnny a block? Can you say aftermarket bow tie? Sure you can.
So your mad at mopar because you need a 763 ci motor to go fast? I'm a little confused with this thread
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: B G Racing]
#1673745
09/20/14 11:12 PM
09/20/14 11:12 PM
camastomcat
Salt Lake City
How about, because there are no more aftermarket steel blocks available, and it really has nothing to do with stock blocks. It has to do with people wanting to make 1000 HP with stock blocks, -1 heads, $3000 aluminum blocks, Chinese crankshafts, and main girdles. It has to do with trying to qualify for T/D with a 4.800 BS N/A motor. I really feel for the N/A Mopar 10.5 tire guys, if they even exist. Ask Bob R., Al, Monte, Steve Gill, Pete Costas, ETC. Unlike some, we like to run something besides our mouth, and make a faster and faster field every year. That's where the frustration is, not to mention spending ten's of thousands for something that qualifies 42 out of 46 cars, then blows up. If that doesn't make it clear to you, I give up trying to explain it.
[Re: camastomcat]
#1673746
09/21/14 12:25 AM
09/21/14 12:25 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Some people are just looking for something that will stay together at 700hp and run the numbers. I think that's in where the real issue lies IMHO.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1673747
09/21/14 04:01 AM
09/21/14 04:01 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The main disconnect here seems to be that the vast majority of Mopar guys are content to run motors in the 750 or so HP range. Be they bracket racers, test n tuners, stop racers, street guys or whatever. In that range parts are plentiful, cheaper and there seems to be no problem getting them..........Then you have a group of guys who want to make more power. They seem to have no problem ponying up the money for mega-blocks, Indy blocks, KB, B-1s etc, but parts are harder to get and a little more costly. The first group seems to have no problem with the second group.........Then comes the third group. The guys who want to make serious power and or be able to compete on a head to head basis with other brands and do it with Mopar power. This is the group that is always lamenting the fact that Mopar R&D and new parts is virtually non existant at this level and pointing out the fact that there are no parts to do what you want and none on the horizon. Some in group one seem to have a real problem with group three and want to label them "elitest" or some such other bullsh%t and call them not REAL Mopar guys because they complain about parts or choose to go other routes to accomplish what they want. They are content and can't seem to understand why others are not..........THAT is the problem. They only see it from their point of view
Monte
[Re: Monte_Smith]
#1673748
09/21/14 04:07 AM
09/21/14 04:07 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Monte
EXACTLY..
Chris..
[Re: Monte_Smith]
#1673749
09/21/14 04:19 AM
09/21/14 04:19 AM
sixpackgut
Charleston
Monte
That is so well written, that i think you should save it and use it next week when the topic come up again.
[Re: Monte_Smith]
#1673750
09/21/14 05:46 AM
09/21/14 05:46 AM
Posts: 494 IL
EchoSixMike
IL
Monte
I suppose it should be pointed out that there is no "mopar/chevy/ford" at that level. It's all custom stuff, as I'm sure you know.
The Mopar crowd, in fact, dominates it all, since there's nothing other than Hemis at the highest levels of drag racing, on whatever fuel, except where the rules force them out. As has been noted before, not least by me, the rules are invariably designed to put butts in the seats and generate revenue. S/F.....Ken M
[Re: Monte_Smith]
#1673752
09/21/14 11:14 AM
09/21/14 11:14 AM
Posts: 3,396 Pa
Hot 340
Pa
Monte
Hey, I'm almost in group 2!
[Re: sixpackgut]
#1673753
09/21/14 11:19 AM
09/21/14 11:19 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Monte
I agree wholeheartedly.
Uh, Tom...that's a really bad business model...all the way around. This is another thing I notice about "Group 3" as Monte calls them. What's the hang up with N/A??? T/D is a power adder class, and more power is being added every day! The chevy guys who can't afford the monster cubic inch stuff have no issues bolting on a blower or a bottle.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1673754
09/21/14 11:51 AM
09/21/14 11:51 AM
camastomcat
Salt Lake City
Yes, that's right, I'm a tad selfish there and want a bracket car, T/D, and S/C car all in one. I'm not so elite as to be able to own 2 cars. If I went one of those way though, it would probably with NOS so I could achieve the other goals. I would still need an aftermarket block.
[Re: Monte_Smith]
#1673755
09/21/14 11:57 AM
09/21/14 11:57 AM
Eric
Pittsburgh PA
Monte
Funny...I bracket race...and god forbid throttle stop race but love seeing the really "fast" cars. How would that change the lack of a block that the vast majority of people desire?
[Re: Monte_Smith]
#1673756
09/21/14 12:42 PM
09/21/14 12:42 PM
Monte
You forgot the part of where the "group three" whines and blames the others because they can't pick up the phone and have the parts they want shipped next day. And they want 20 plus heads to choose from......And blocks available in any bore space and deck height they desire... And then there are the group four guys that are out there racing instead of whining and blaming others about having no parts.....
