which windage tray #167363
12/14/08 12:47 AM
12/14/08 12:47 AM
CT USA
N
Nick Mineau Offline OP
N
CT USA
hi
im running a 66 440 w/stock oil pan. engine runs great but i just pulled it to repaint it. it doesnt have a windage tray in it. it doesnt leak know and i don't want to open a case of worms but would like to install a windage tray while the engin is out. good idea or bad? whats involved? and what are the chances of leaks? thanks
also whats the best tray to use with the stock 5 quart oil pan?
Re: which windage tray [Re: Nick Mineau] #167364
12/14/08 12:59 AM
12/14/08 12:59 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
i dont know which is best,but if its a mild engine then the mp tray probably works as well as any.chrysler used to say it was worth up to 15 hp at 6000.and since it was designed for a stock pan it would be a good choice. its not a bad idea to take a screwdriver and pry open the slots a little more.
Re: which windage tray [Re: Nick Mineau] #167365
12/14/08 03:56 AM
12/14/08 03:56 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
On a 440 the tray mounts between the pan and block using 2 gaskets. The Milodon piece is far superior as it allows much better drain-back than the solid MP piece does. The MP can and is often modified but for the extra dollars the Milodon is the deal IMO.
Ride eternal, shiny and chrome
Re: which windage tray [Re: DirectSubjection] #167366
12/14/08 12:56 PM
12/14/08 12:56 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I installed the Milodon in my 383. Nice product.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: which windage tray [Re: Nick Mineau] #167367
12/14/08 05:25 PM
12/14/08 05:25 PM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
I have a Direct Connection tray, two gaskets always leak ,,,,,,,, solution is easy just cut the flange off the tray and have it weld into the pan ,,,,,,,,, did that over 20 years ago still have the car and zero problems,,,,,,,,,, pan even comes off with motor in the car....l
Re: which windage tray [Re: Lawn Monkey] #167368
12/18/08 08:18 PM
12/18/08 08:18 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I picked one up from Summit today (I love living 30 miles from one of their outlets). I also snagged two Milodon gaskets. Do you install them dry or with a touch of RTV for best results?
