8.25 to a 8.75 rear with 4 speed, different driveshaft? #167292
12/13/08 09:39 PM
12/13/08 09:39 PM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Hello,
My 72 Duster currently has a 318, 4 speed OD tranny and an 8 1/4 rear out of an F-body(wider), and I'm looking for a new stock width or narrower rear to replace it. Will the driveshaft need to be swaped if I go from an 8 1/4 to an 8 3/4 rear? If so does it need to be longer or shortened? I havent found one yet but I want to get all my info together. The car has the springs moved in 3"s on each side and I plan on mini-tubbing it and with the 59 1/2" rear in it now it would be almost imposible to find wheels with that much backspacing. Thanks
Butch
Hazlet, NJ
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: 440Satellite] #167293
12/13/08 09:52 PM
12/13/08 09:52 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
you'd have to shorten your shaft, but you probably have the small u joint anyway. Time to step up to a bigger u joint anyway. Go with an aluminum shaft
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: farmington] #167294
12/13/08 10:01 PM
12/13/08 10:01 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Ok, thanks, figured it wouldnt be the same. Yeah I dont know what the current driveshaft is now, I would quess the small u-joints with a 318, but I'll have to check. What does a new driveshaft cost, ballpark?
Butch
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: 440Satellite] #167295
12/13/08 11:02 PM
12/13/08 11:02 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
That size corresponds to a C-body rear end, A-bodies are like 51.40" F-bodies 54" you can have a driveshaft shortened pretty easy if you check the yellow pages for driveline shops. Good luck.
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: 68Fastback] #167296
12/14/08 12:10 AM
12/14/08 12:10 AM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
The rear is 59 1/2" from the outsides of the drums or wheel mounting surfaces , I know the A-Bodies are around 57 1/8 drum to drum, so I figure a stock A body or narrowed rear would work good, something 52-58" Drum to drum maybe.
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: 440Satellite] #167297
12/14/08 01:56 AM
12/14/08 01:56 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Sorry I did not see drum to drum not backing plate.
http://www.moparts.org/Tech/Archive/axle/17.html
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: farmington] #167298
12/14/08 02:08 AM
12/14/08 02:08 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Isnt that sorta overkill considering hes running a 318 and an OD833? I doubt a shortened stock steel driveshaft and a 7260 joint will be his weak point anyway
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: 69L78Nova] #167299
12/14/08 12:01 PM
12/14/08 12:01 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Yeah its only a mildly modified 318 and aluminum 4 speed od tranny. I do plan on building a 408 stroker in the future but thats a ways off(probably 2 years ), plus I dont know if I'd stick with the 4 speed or go with a 727 instead. I would guess that the driveshaft length would be different with a 4 speed and a 727 tranny, right?
Re: 8.25 to a 8.75 rear with 4 speed, different driveshaft? [Re: 440Satellite] #167300
12/14/08 12:19 PM
12/14/08 12:19 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Yes, the 727 tailshaft is longer than an A-body 833 tailshaft.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
