crank to cam center to center dimension on 318LA #1672457
09/16/14 09:26 PM
09/16/14 09:26 PM
Western PA
O
OldMoparMan Offline OP
O
Western PA
I have been measuring up a block to get some work done on it and can't seem to find the center to center dimension for the crank to camshaft fits.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: crank to cam center to center dimension on 318LA [Re: OldMoparMan] #1672458
09/17/14 12:07 AM
09/17/14 12:07 AM
I cant say that I have ever seen that dimention. Shops measure crank centerline up to each of the two decks on each end 4 measurements) to square deck it to get all 4 corners equal
Re: crank to cam center to center dimension on 318LA [Re: OldMoparMan] #1672459
09/17/14 07:48 PM
09/17/14 07:48 PM
Western PA
O
O
Western PA
I got those dimensions already and my block is only off by .001 front to back but .008 from 1 to 2 and 7 to 8 but when I tore it down the back cam plug had wear on it from the cam so I was going to see if that bore was true to the crank.
