Broken/Worn off Caster/Camber Bolt guides? #1672359
09/16/14 06:32 PM
09/16/14 06:32 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Is there a solution. The Guides for the upper control arm Cam bolts on my 1977 D100 are done for.
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: midnite360] #1672360
09/16/14 06:55 PM
09/16/14 06:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What do you mean by guides? If you are talking about the offset washers you get them at the parts store. If you are talking about the bracket attached to frame I think you're hosed.
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: stumpy] #1672361
09/16/14 07:09 PM
09/16/14 07:09 PM
Goodyear Arizona
Goodyear Arizona
Yup, the part riveted to the frame... That is not what I wanted to hear
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: midnite360] #1672362
09/16/14 07:14 PM
09/16/14 07:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might be able weld something up if you are good at it.
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: stumpy] #1672363
09/16/14 07:19 PM
09/16/14 07:19 PM
Goodyear Arizona
Goodyear Arizona
Yeah, I guess so... Hopefully I can figure something out.
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: midnite360] #1672364
09/16/14 07:28 PM
09/16/14 07:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you could get the right measurements off the old pieces and then grind them down and weld a pair of metal strips in their place. It should work.
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: stumpy] #1672365
09/17/14 02:39 AM
09/17/14 02:39 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've made a few sets over the years, they are not that difficult to make copies of and get them welded on. If a hack like me can do it, anyone with a little fabrication skills should be able to do it as well. its a pita place to work, but its doable. Gene
Re: Broken/Worn off Caster/Camber Bolt guides? [Re: poorboy] #1672366
09/17/14 08:44 AM
09/17/14 08:44 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I don't know if this will apply to the front, but on the rear of my 73 when the spring perches were shot I ground the rivets, knocked them out and replaced the whole bracket assembly with a good one using grade 8 bolts. I can't remember if this would be an option on the front.
...FAFO...
