Page 2 of 3 1 2 3
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1672014
09/17/14 06:03 PM
09/17/14 06:03 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Jenkins ran those "cheap" regulators too! I've had nothing but a Holley blue pump on my car since 1981.Not the original pump,as I'm on my 3rd one,but I know I could rebuild the other 2 and they would work just as well.
Nautilus Racing-
Re: Holley Blue pumps and regulators? [Re: JCCuda] #1672015
09/17/14 06:35 PM
09/17/14 06:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is a picture of one of Bob Glidden's Clevelands from about 1979-80. Pro Stock cars were going mid 8's at that time. Note the fuel system in the picture. Check out the water pump drive too. Pretty trick stuff.
They made it work cos that`s all they had till "Bogus Junk" (BG)came along trying to up things a bit w/some success..............key word "some" success. If the blues were that bad azz how come pro stock doesn`t run em today............. Regulators yes pumps no way in hell they`ll work. I ran the Aeromotive hot rod pump on my car and it fell on it`s face and some of you agreed watching my 9.98 video..........maybe a bad pump don`t know or care since now I`m solidly in the 9`s and wasn`t before.
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672016
09/17/14 06:48 PM
09/17/14 06:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is NOTHING MAGIC about a regulator... it has a
hole and a spring to let the set pressure by.. I dont
care for the NON return style reg due to fuel pressure
fluctuation and I run a return style(I have for 20
years now).. yes at one time I did run the cheapo
holley reg but then I started working in the fuel
lab and seen the benefits of the return style systems
and have been that way since
Re: Holley Blue pumps and regulators? [Re: MR_P_BODY] #1672017
09/17/14 07:32 PM
09/17/14 07:32 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Make sure the rubber diaphragm is still soft and pliable and does not have holes! They dry out and that causes problems.
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672018
09/17/14 08:42 PM
09/17/14 08:42 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
They made it work cos that`s all they had till "Bogus Junk" (BG)came along trying to up things a bit w/some success..............key word "some" success. If the blues were that bad azz how come pro stock doesn`t run em today............. Regulators yes pumps no way in hell they`s work. I ran the Aeromotive hot rod pump on my car and it fell on it`s face and some of you agreed watching my 9.98 video..........maybe a bad pump don`t know or care since now I`m solidly in the 9`s and wasn`t before.
Come on, don't you think the fuel demands of TODAY'S 500" motor (1200 HP?) are a wee bit different that those in the 80's??
I'm saying that if those "junk" blue parts supported 7.80's @ 170+ MPH, then many of you 9-10 second guys buy the "trick" stuff because other guys and the marketing firms tell you to.
Re: Holley Blue pumps and regulators? [Re: cudadoug] #1672019
09/17/14 08:49 PM
09/17/14 08:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Again, my car fell on it`s face past the 1/8th w/a black Holley and the Aeromotive.............installed the 300 Magnafuel and had to re-tune the carb and went solid 9`s. And my car`s not that bad azz............
Re: Holley Blue pumps and regulators? [Re: Chris2581] #1672020
09/17/14 08:56 PM
09/17/14 08:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Not anymore, the lower hsg was discontinued several years ago.
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672021
09/17/14 08:57 PM
09/17/14 08:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You need .5 pounds of fuel for 1 HP per hour... its
just math... but all of use run WAY more than needed
when it comes to pumps.. BUT hopefully its the last
one you ever buy... I have tended to buy 2 cheaper pumps
as in the blue Holleys and run them in parallel for
the volume(pounds per hour) and it ends up cheaper
than 1 big pump.. by a lot
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672022
09/17/14 09:16 PM
09/17/14 09:16 PM
cudadoug Offline
cudadoug  Offline
Ummmm, if you "had to retune the carb", how do you KNOW the pump/reg was causing your problems?
I once tried a billet cement mixer pump and high $$ reg on a low 10 second combo, replacing JUST the 10 year old Blue pump and reg. Adjusted the PSI to be the same, and ran it. Weather station was identical to the weekend before and said I should go 10.30's based on my data. (With the old Holley stuff).
Guess what??? 10.30's at the same speed with the new (thankfully borrowed) high $$ "junk".
It LOOKED trick though...
Re: Holley Blue pumps and regulators? [Re: cudadoug] #1672023
09/17/14 09:39 PM
09/17/14 09:39 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Gotta agree with ya. My old 9.80's car( 3350 weight) ran a Holley black and Holley large port regulator for years. Ultra consistent car, saw about 7500 at the stripe every pass.
I caved in to peer pressure and went hog wild witha return style way bigger pump/ lines,etc, etc..... And saw zero difference after throwing a grand at a nonexistent problem.
My new car is much slower, but I run a pump similar to a black on it through the stock tank sock, 5/16 line and small Holley regulator. It pulls hard on the back half
of the track for what it is, zero nosing over. I have no concerns it's leaning out.
Just my
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Holley Blue pumps and regulators? [Re: cudadoug] #1672024
09/17/14 09:42 PM
09/17/14 09:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I upped pressure and jetted it to the moon to get it to somewhat run to get the "volume" I needed and ran ok. New 300 pump re-tweek and string of 9`s no other changes BUT, I am a lucky hack so maybe that`s it...........
Re: Holley Blue pumps and regulators? [Re: B3422W5] #1672025
09/17/14 09:46 PM
09/17/14 09:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just my
Small motor, small demands try that w/a stout big block and report back with us. Also do you have a wideband? Install one then you`ll see the fuel curve w/your own eyes and can verify not assume..........My car pulled like a beast, went to chassis dyno and was approaching dangerously lean 16.1 numbers..............
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672026
09/17/14 09:52 PM
09/17/14 09:52 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I ran a black billet Holley pump and a small port Holley regulator on my Dart, at the 1/8 mile my pressure would be around 2 pounds. I put a new Magnafuel Quickstar 275 and a Holley big port regulator and my fuel pressure stays near 6 pounds now. I don't know if the regulator or the pump fixed my issue, but one of them did.
Re: Holley Blue pumps and regulators? [Re: justinp61] #1672027
09/17/14 09:53 PM
09/17/14 09:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Total bs.NO WAY.............
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672028
09/17/14 10:02 PM
09/17/14 10:02 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Hard to believe I know ..........
Re: Holley Blue pumps and regulators? [Re: cudadoug] #1672029
09/17/14 10:22 PM
09/17/14 10:22 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I have REALLY hurt some guys feelings about their fuel regulators on my flow bench...........LOL!!.....Those "cheap" Holley regulators are the most repeatable and consistent regulator you can buy. The only drawback they have is the inner flow path diameter. But it requires BIG power to need more fuel than they can deliver and they are more than enough reg for 99% of guys
Monte
THIRTY YEARS AGO, the first 500" P/S cars were in the 7's, right? Holley Blue pumps and those cheap dead head regulators were the real deal.
So I cannot help but when a guy tells me that his motor NEEDS that $500 billet cement mixer pump and $200 regulator on his 9.80/135 mph car, "Cause it was too lean with the Holley stuff". YEPPERS, just had a Mopar racer tell me that a few weeks ago when I asked about his recent fuel system "upgrade". Oh, and he's really puzzled how there isn't any gain on the time slip...
I totally agree with both of these statements.
I used a Holley Blue and regulator with no issues.
10.0@ 136 doesn't miss a beat.
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672030
09/17/14 10:27 PM
09/17/14 10:27 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Just my
What do you mean, small motor small demands? Car ran the same numbers yours does and was 150 pounds heavier
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Holley Blue pumps and regulators? [Re: B3422W5] #1672031
09/17/14 10:36 PM
09/17/14 10:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Trust me, that 9.79 was my first full boogie pass and had several issues w/the carb and suspension so a 9.59-9.64 is comin soon. And kudos, your car hauled azz..............
Re: Holley Blue pumps and regulators? [Re: Thumperdart] #1672032
09/17/14 10:45 PM
09/17/14 10:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Quit being so nice. You make it hard to pick on ya
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Holley Blue pumps and regulators? [Re: B3422W5] #1672033
09/17/14 10:47 PM
09/17/14 10:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know, that`s why I do it and it must be working cos Quicktree`s been leaving me alone............
Page 2 of 3 1 2 3
