Page 1 of 3 1 2 3
Holley Blue pumps and regulators? #1671994
09/16/14 04:22 AM
09/16/14 04:22 AM
Mississippi
Mr. T Offline OP
Mr. T  Offline OP
Mississippi
How good are they usually. I borrowed both from a friend this past weekend. The fuel pressure would never stabilize. At 7 pounds the engine would flood out and die while idling. At 5 pounds, the car would slow down. Had to constantly adjust the pressure. In all fairness, the system had not been used in about 3 years. What has been your experience with them?
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1671995
09/16/14 04:43 AM
09/16/14 04:43 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
my blue pump went bad after one summer of weekend street use!
Re: Holley Blue pumps and regulators? [Re: ademon] #1671996
09/16/14 04:56 AM
09/16/14 04:56 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I used to go through a lower housing per year. They all started to leak. Other people have zero issues.
Re: Holley Blue pumps and regulators? [Re: Leigh] #1671997
09/16/14 05:35 AM
09/16/14 05:35 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you get what you pay for. after having issues with the std holley blue regulator, i bought a Mallory. instantly the pressure guage stabilised & the carb no longer starved for fuel. after pulling the Holley regulator apart, i realised why they're rubbish. i now use a Magnafuel pump & regulator & have zero issues. i modified the Holley blue pump to be my trans cooler flushing pump, it seems to be in it's element in that job. hand on heart i'll never use a Holley blue pump & reg on any car i own til the day i die. cheap junk pump & regulators are for cheap junk cars. i own a Mopar so thats removed the cheap junk part of my story.
Re: Holley Blue pumps and regulators? [Re: rebel] #1671998
09/16/14 05:55 AM
09/16/14 05:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran the Holley red pump for many years that uses the built in regulator and it was rock solid at 6 psi. In fact I ran 10.70's with the Holley red pump. Then switched to the Holley black pump about 2 years ago with this regulator here that I bought with the pump at a local speed shop. I set the regulator at 6 and it has been flawless for the 2 years its been on the car. And it runs 10.70's with it also. I only went to the larger Holley black pump because I was afraid the red pump would not supply enough fuel as its rated at 98 GPH I believe and the black is rated 140 GPH. But the red was giving me enough as it runs the same mph and et with the black pump and regulator. But its rock solid at the 6 PSI where I set it and I have had no problems. I have run Holley red and blue pumps since the 70's with no problems. I went with the black this time because its rated a bit larger then the blue. Ron
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1671999
09/16/14 09:27 AM
09/16/14 09:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to use 2 holley blue pumps in parallel on my
car some years back but I hated the cheap holley
regulators so I went with a mallory 4 port with return..
I run a return system on all my junk... now I have
2 holley blacks in parallel with the same reg.. on
my Rampage I have a single Mallory 140 pump but that
will be coming off and going with injection
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1672000
09/16/14 09:29 AM
09/16/14 09:29 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Never had any issues, the car used a black pump and I use the 12-803 regulator for the motor and nitrous which also has it's own black pump. I even use a blue pump every day winter and all as a lift pump on my Cummins. Zero problems here.
Re: Holley Blue pumps and regulators? [Re: 383man] #1672001
09/16/14 10:31 AM
09/16/14 10:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have one on this car and I haven't had one issue. I keep my pressure at 6. Been on the car for 3 years and I think it was used when I bought it.
Coming soon!!!!
Re: Holley Blue pumps and regulators? [Re: Mr.Yuck] #1672002
09/16/14 10:47 AM
09/16/14 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never had any real issues with the blue pumps
other than they are LOUD but I guess I am a little
more into quiet.. even when we tested pumps in the lab
at work... I've never found any pump quiet
Re: Holley Blue pumps and regulators? [Re: MR_P_BODY] #1672003
09/16/14 11:02 AM
09/16/14 11:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had great luck with them. I carry a spare on dragweek but have yet to need it.
68 Barracuda Formula S 340
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1672004
09/16/14 11:17 AM
09/16/14 11:17 AM
gregsdart Offline
gregsdart  Offline
Check your free flow rate with the system you have before making any change. The blue pumps put out enough fuel for up to 500 hp, and the regulators have worked well for me in the past. I am not a fan of the blue pumps though, I have a box full of bad ones. If you are at about 500 hp, then the free flow rate should be about one gallon per minute to feed that much power under pressure.
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1672005
09/16/14 04:14 PM
09/16/14 04:14 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Ran 2 Holley blue pumps in series from 1988-2006. Same pumps and regulator never an issue. Car ran 10.80-10.90 from 1988-2000. Upgraded the engine and got the car down to 10 teens w/the same set up. Only leak I ever had in my fuel system was the big Fram fuel filter.
Ok
Re: Holley Blue pumps and regulators? [Re: cudatom] #1672006
09/17/14 12:37 AM
09/17/14 12:37 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I ran a blue with two Holley regulators with no issues.......for a lot of years.
It got busy as far as plumbing.......from the pump to a Y block on the fender well , regulator on each output into lines that came in to an aluminum block I made that had two inlets and outlets and the pressure gauge pick up point in it.
The block was mounted on the carb heat shield.
I seem to remember reading that the volume restriction was in the regulator and that was what pushed me in that direction.
Stepped up a bit on this deal , but knowing what I know now I think a return system regardless of who's pump is the way to go.
Re: Holley Blue pumps and regulators? [Re: cudatom] #1672007
09/17/14 12:46 AM
09/17/14 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why would you run 2 pumps in series and not parallel
Re: Holley Blue pumps and regulators? [Re: Mr. T] #1672008
09/17/14 01:48 AM
09/17/14 01:48 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Hey Tim. I'd be very concerned about any fuel system components that have been dormant for some years and put back in use. New they would be fine for your deal. PM me
Re: Holley Blue pumps and regulators? [Re: goldmember] #1672009
09/17/14 02:43 AM
09/17/14 02:43 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I have REALLY hurt some guys feelings about their fuel regulators on my flow bench...........LOL!!.....Those "cheap" Holley regulators are the most repeatable and consistent regulator you can buy. The only drawback they have is the inner flow path diameter. But it requires BIG power to need more fuel than they can deliver and they are more than enough reg for 99% of guys
Monte
Re: Holley Blue pumps and regulators? [Re: Monte_Smith] #1672010
09/17/14 03:55 PM
09/17/14 03:55 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Monte
THIRTY YEARS AGO, the first 500" P/S cars were in the 7's, right? Holley Blue pumps and those cheap dead head regulators were the real deal.
So I cannot help but when a guy tells me that his motor NEEDS that $500 billet cement mixer pump and $200 regulator on his 9.80/135 mph car, "Cause it was too lean with the Holley stuff". YEPPERS, just had a Mopar racer tell me that a few weeks ago when I asked about his recent fuel system "upgrade". Oh, and he's really puzzled how there isn't any gain on the time slip...
Re: Holley Blue pumps and regulators? [Re: cudadoug] #1672011
09/17/14 04:02 PM
09/17/14 04:02 PM
Guitar Jones Offline
I use 2 Holley blue pumps and regulators on my junk, one for each carb. I've never had a problem unless they sit around dormant for years. BTW I've done the fuel flow test years back with a .110 orifice and these pumps and regulators flowed more than enough to feed my engine.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Holley Blue pumps and regulators? [Re: cudadoug] #1672012
09/17/14 04:26 PM
09/17/14 04:26 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
This is a picture of one of Bob Glidden's Clevelands from about 1979-80. Pro Stock cars were going mid 8's at that time. Note the fuel system in the picture. Check out the water pump drive too. Pretty trick stuff.
Re: Holley Blue pumps and regulators? [Re: JCCuda] #1672013
09/17/14 05:19 PM
09/17/14 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL.. notice ALL of the RUBBER fuel hose.. I guess that
was before the 6" rule started
Page 1 of 3 1 2 3
