Page 7 of 8 1 2 3 4 5 6 7 8
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671652
11/24/14 01:25 AM
11/24/14 01:25 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Enkei's are good wheels no doubt.
Mopar to the bone!!!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671653
11/25/14 12:12 AM
11/25/14 12:12 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Got some bad news today... The distributor (THMotorsports) called me up and said when he went to go order the wheels from Enkei, that they were discontinued. So, now I'm back to square one, sorta. He recommended I take a look at SSR Wheels (they're pricey), and if needed be, he may try calling Enkei again and try working something out so I can get the correct sized and offset wheel.
On the plus side, Dr Diff sent in my new spindles that just arrived today and tires should be in on Wednesday, if not next week.
I just tried searching all over the web for wheels and can't really find much that would utilize no spacers besides this: http://www.summitracing.com/search/brand...;SortOrder=Desc
The next best offset I can find is +24mm and the cheapest alternative would be the American Muscle website or I could get quality Enkei's. However, odds are, I'd need like a 3/8" spacer.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671654
11/25/14 01:26 AM
11/25/14 01:26 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'm pretty fond of these. EBay 251680469805
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671655
11/25/14 01:36 AM
11/25/14 01:36 AM
SoCal
SoCal
They look good but only come in a +35 or +45mm backspacing. I'd need like a 20mm spacer... Almost all of SSR's wheels in 18 x 9 are +35mm offset or higher.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671656
11/27/14 12:01 AM
11/27/14 12:01 AM
SoCal
SoCal
Tires came in last night and holy crap do they look bad @$$. I'm still on the hunt for wheels. Would it be all that bad trying to use an 8.5" wheel? It still fits within the tire specs.
Edit: And as I've been slowly figuring out... No one makes an 18 x 9" wheel. Literally, every wheel manufacturer's page I go to skips straight from 8.5" to 9.5".
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671657
11/28/14 06:42 PM
11/28/14 06:42 PM
SoCal
SoCal
Anyways, I found some wheels that will fit my application, they cost more than the RP03's, but I called the distributor up and he's going to check with the wheel manufacturer on Monday to see if the wheel manufacturer has them in stock, as he only has the rears on him and I don't wait 6 months for wheels. He said, if needed, be he'd even cut the price down on these wheels so that they'd be cheaper than what I would have paid for the RP03's. Talk about awesome customer service!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671658
12/07/14 05:12 PM
12/07/14 05:12 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
This is what 285 front and 305 rear look like, winning last weekend...
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671659
12/07/14 05:16 PM
12/07/14 05:16 PM
SoCal
SoCal
Nice! By a good 1.5 seconds. How does the larger tires in the back feel vs a square setup?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671660
12/07/14 06:02 PM
12/07/14 06:02 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Samy I went full tight on the rear Swaybar and changed to the 305/30/19 Hankooks on 10.5 inch wheels and it was a beast, particularly in the slaloms. The rear just stuck. I would recommend squeezing in the most rear tire possible...
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671661
12/07/14 06:08 PM
12/07/14 06:08 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Tom, did you have to do any mini tubbing to the inner wheel well?
Did you remove the double wall on the outer wheelhouse?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671662
12/07/14 06:16 PM
12/07/14 06:16 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Way to represent the Tbar brigade Tom!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671663
12/07/14 08:42 PM
12/07/14 08:42 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Thanks! It's always fun winning... Inner wheel well is stock, outer fender has been pushed out and massaged with a pneumatic tool, lips folded over flush...
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671664
12/07/14 08:53 PM
12/07/14 08:53 PM
So Cal
So Cal
.... Inner wheel well is stock, outer fender has been pushed out and massaged with a pneumatic tool, lips folded over flush...
Did you flatten/slice the double wall on the outside?
This is after I rolled the lip up. The outerside of the inner wheelhouse starts turning inwards.
Looking upwards
Do you have this ridge/lump on your Valiant?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671665
12/08/14 01:09 AM
12/08/14 01:09 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
SVE Drift wheels on my car, they cost $150-$160 each. Sold for Mustangs... by Late Model Restoration. I mixed and matched years to get the size and offset I wanted.
Fits 1994-2004 Model Year Mustang
Offset: +24mm
Backspacing: 5.95
Lug Pattern: 5x114.3
Weight: 24 lbs
Offset: +22mm
Backspacing: 6.36
Weight: 25 lbs
If you need deeper offset, then the 2005-2014 Mustang is:
18x9"
Offset - +35mm
Backspacing - 6.38"
Weight - 23lbs
18x10"
Offset - +43mm
Backspacing - 7.20"
Weight - 24lbs
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671666
12/08/14 01:21 AM
12/08/14 01:21 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Unless you did some significant modification and an aftermarket style tub all our cars have a similar "lump", this is where the outer wheelhouse kicks out to attach to the quarter.
Here is a picture of mine. Car was minitubbed by putting a new inner wheelhouse on and spanning the 3" gap with a flat piece of metal. We also trimmed and rolled the lip where it needed clearance at the top edge.
-Michael
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 68cuda440] #1671667
12/08/14 01:24 AM
12/08/14 01:24 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I'll get you guys some pics in the AM
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671668
12/08/14 01:33 AM
12/08/14 01:33 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mine doesn't have THAT much of one.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 68cuda440] #1671669
12/08/14 01:47 AM
12/08/14 01:47 AM
SoCal
SoCal
Offset: +24mm
Backspacing: 5.95
Weight: 24 lbs
Offset: +22mm
Backspacing: 6.36
Weight: 25 lbs
18x9"
Offset - +35mm
Backspacing - 6.38"
Weight - 23lbs
18x10"
Offset - +43mm
Backspacing - 7.20"
Weight - 24lbs
-Michael
I think I may need to go this route with the 18 x 9's and the +24mm and +35mm offsets, but I don't think I'm seeing them on AMR's website.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671670
12/08/14 01:59 AM
12/08/14 01:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Offset: +24mm
Backspacing: 5.95
Weight: 24 lbs
Offset: +22mm
Backspacing: 6.36
Weight: 25 lbs
18x9"
Offset - +35mm
Backspacing - 6.38"
Weight - 23lbs
18x10"
Offset - +43mm
Backspacing - 7.20"
Weight - 24lbs
-Michael
You have to be specific about the year on their site. Some wheels are only available for certain years. But you want 94-04 FRONTS for your rears and 05+ fronts for your fronts.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671671
12/08/14 02:07 AM
12/08/14 02:07 AM
SoCal
SoCal
Offset: +24mm
Backspacing: 5.95
Weight: 24 lbs
Offset: +22mm
Backspacing: 6.36
Weight: 25 lbs
18x9"
Offset - +35mm
Backspacing - 6.38"
Weight - 23lbs
18x10"
Offset - +43mm
Backspacing - 7.20"
Weight - 24lbs
-Michael
I didn't find SVE Drift wheels on their websites and I was looking for 18 x 9's on for both 94-04 (for my rears) and 05+ (for my fronts). Anyways, I think I found a Mustang wheel on Summit with the right offset that I'm going to order tomorrow. 18 x 9's, +24 for the rear and +33 for the fronts. I'll just use a spacer, and maybe some 3" studs and call it at that. Dealing with the other companies have been a pain.
I finish finals on Wed so it's soon time to get...
