Page 1 of 8 1 2 3 4 5 6 7 8
275 Series Tires, A-bodies, and Offset Shackles #1671532
09/15/14 10:17 PM
09/15/14 10:17 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Just curious... For you guys who are running a 275/35/18 or equivalent tire in a stock wheel tub A-body. Did you guys use offset shackles? I've been asking around and doing some measurements and it doesn't seem like they'd fit without one. I've also got a stock width A-body rear end with Dr Diff's kit on it. I just don't recall anybody mentioning needed them. How do the offset shackle kits work? I'm assuming you have to move the perches in.
I found a deal on CL for some bullet 2 piece wheels on CL. 2 piece wheels means I could probably get someone to cut the welds and set it to an offset I need. Or I could just use a spacer. Fronts are 18 x 8" with a 245/40/18 tire and rears are a 18 x 10 with a 275/35/18 tire on it. Offsets are unknown. Honestly, I don't think anything more than a 255/40/18 will fit or maybe a 265/35/18 (may look a little funky as the fronts would be smaller than the rears). Only info I got is that they were originally made for a '72 Mustang but now put on a newer one. Judging by the pictures, the rears seem to have close to 0 mm offset as it sticks out past the quarter panels on the newer Mustang.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671533
09/15/14 10:18 PM
09/15/14 10:18 PM
SoCal
SoCal
Another picture...
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671534
09/16/14 12:36 AM
09/16/14 12:36 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You can generalize through all A-body.
The body style/shape dictates the distance to the place the outer edge of the tire will rub.
67-69 Darts are just like your 68. Even 70-72 Darts are the same in the rear. And very close in the front as they take a different wheel lip moldling.
GMachineDart would be a good guy to benchmark from.
On my 68 Dart: 245/60/15 15x7 with 4.25" to 4.5" backspacing depending on small or large bolt pattern is about all the rear will take with the car lowered. My rear wheel lips are not rolled and the body has a tiny be more room to the quarter on one side.
Sure there are people that have got more, but make sure their back ends are not all jacked up.
IMHO, the springs are only about 1/2" past the inner fender. But when the rear end rolls, the top of tire tilts in relative to the body. So you need some room there.
In the front I've barely got 225/60/15 on 15x7 4.25" backspacing rim. I've got 245/60/15 with 15x6.5 rims BUT I moved the bottom front of the fender out.
Might consider some 16x7's 5.0" backspacing with 245/50/16's. Then run 1/2" billet spacers in the rear. Or maybe 17x7's and you probably will have to mess with the bottom front fender lip some. Hopefully GMachineDart has some better insight.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671535
09/16/14 12:47 AM
09/16/14 12:47 AM
SoCal
SoCal
I'm going to have the full Hotchkis TVS with Dr Diff's 13" brembo-style calipers in front and 11.7" Cobra calipers in the rear. My rear end is stock A-body length.
Thanks through my research tonight, that's what I've been finding out. I was able to get more information about the wheels above. fronts are 18 x 8's with a 7mm offset and rears are 18 x 10's with a 0mm offset. He was running spacers on his Mustang so I might ask for them if I decide to pick them up tomorrow as I know the fronts won't fit. I believe rears should be able to fit fine. Worst case scenario I'll trim the lip. If I pick these up tomorrow, I might just order some new 245/40/18 tires for the front and 255/40/18's for the rear on clearance from TireRack (trying to save some money instead of forking over $2500 for new wheels and tires). I'll probably sell the fronts on CL for cheap (to recover some money) and save the 275/35/18 for the future (in case I want to mini-tub or use offset shackles).
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671536
09/16/14 12:55 AM
09/16/14 12:55 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Typically large bolt pattern axles move the flange out 3/16 to 1/4" because they have thicker flanges than small bolt pattern axle flanges.
I'm not intimately familiar with Dr Diff rear rotors, but are they thicker where they mount to the axle than the drums you took off that 8 3/4 ?
If so, how much? If so, they makes you rear a little wider too.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671537
09/16/14 01:01 AM
09/16/14 01:01 AM
SoCal
SoCal
Just did a rough measurement with the rearend in the car using a tape measure. Rotor face to Rotor face is ~59". So if a stock A-body rear is 57 1/8" drum-to-drum than I added an extra 15/16" on each side? ~24 mm? Does that sound right?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671538
09/16/14 01:17 AM
09/16/14 01:17 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Check with Dr Diff who you bought the axles and brake kit from.
Is the center section out of the rear? If not you have to bend the tape measure around and give you a bad measurement. Better to take a long straight edge against the end of the axle with the rotor clamped on. Then extend the straight edge to the floor. Mark floor. Then do some on other side. Then measure between marks on floor.
Your rear end has 43" between leaf spring hole centers correct? Not 44"?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671539
09/16/14 01:21 AM
09/16/14 01:21 AM
SoCal
SoCal
The rear end is completely assembled in the car including the brakes. I avoided the center section hump by measuring from the top of the pad contact surface to the top pad contact surface (~55.5") on each rotor. Then I measured from the pad contact surface to the wheel surface (~1.75") and multiplied by two. Adding it together gets ~59".
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671540
09/16/14 01:29 AM
09/16/14 01:29 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
My car has the very same Front and Rear Dr Diff brake package. Car is a '68 Barracuda. Front is 255/40-18 on 18x9 with a +35mm offset. This is a fitment for a 2005-2014 Mustang. Wheels cost me $150 each from "Late Model Restoration". http://www.latemodelrestoration.com/item/SVE-1007FC/2005-12-Mustang-Flat-Black-SVE-Drift-18X9
Rear I am running 295/40-18 on 18x10 with +22mm offset. This is a fitment for a 1994-2004 Mustang and cost $160 each. I am running a 1/2" spacer, but my axle is narrowed 7/8" per side from stock. These wheels would fit perfectly on my car with the stock axle width. My axle is narrowed to fit a 12" +25mm offset wheel in the center of the wheel well. The inner wheel housing is flush to the frame AKA mini-tub. So I can run 15x10 1" offset and fit 325/50-15 under the car. Likewise I can run 19x12 and a 325/30-19.
http://www.latemodelrestoration.com/item/SVE-1007FA/1994-04-Mustang-Flat-Black-SVE-Drift-18X10
Only issue with the front on the SVE wheels is I will not be able to run the plastic wheel center caps or I will have to make something special that will fit over the grease cap.
Here is a decent set of pictures showing how the wheels sit:
http://www.forabodiesonly.com/mopar/showpost.php?p=1970389961&postcount=233
Modifications to clearance front edge of front fender on the Barracuda:
https://board.moparts.org/ubbthreads/show...rue#Post8094659
Pictures the day it came home from paint:
http://www.forabodiesonly.com/mopar/showpost.php?p=1970471762&postcount=296
Here is an older picture with the 15x10 and 325/50 Drag radials:
http://www.forabodiesonly.com/mopar/showpost.php?p=1326615&postcount=20
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671541
09/16/14 01:35 AM
09/16/14 01:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
An 18x9 is an big as you can fit. The front a bs of 6-6.5 will fly and a 275/35/18 clears. The rear you have to nail on the bs with offset shackles to work. If it were me with stock rear tubs I would find a set of 4 matching wheels with a bs that works in the front and just use a spacer in the rear to make it up.
Mopar to the bone!!!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 68cuda440] #1671542
09/16/14 01:35 AM
09/16/14 01:35 AM
SoCal
SoCal
-Michael
Ok, I've seen your car quite a bit on FABO. This is a good reference for me.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671543
09/16/14 01:36 AM
09/16/14 01:36 AM
SoCal
SoCal
Yeah, also talking about this on FABO. We didn't realize the brake and bbp axles stuck out so far. I may try doing an 18 x 9" on all 4 corners with the same bs and just running 255/40/18's.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671544
09/16/14 01:42 AM
09/16/14 01:42 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Not by much. The outside face of the rotor I have in the rear sits just below flush on the center register on the axle, so yes it is thicker than the stock drum.
The front kit he has is the same as mine. It is like taking a Cordoba hub and cutting the rotor off. Then add the rotor thickness. So it ends up a bit wider than the Cordoba brakes. I think Cass designed it to work with the late model Mustang wheel offsets. To get the same size front and rear and get them to sit right, like a 17x8 wheel for example, you would probably have to go with a small 1/2" spacer on the rear.
I would just ask Cass (Dr Diff), he sells the kits and knows what works.
-Michael
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671545
09/16/14 01:55 AM
09/16/14 01:55 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
That should fit easily, too bad you are not local, I know where a few wheels are you could test fit. Do a few quick measurements on the rear, I think the 18x9 w/ +35mm to +38mm should work fine for you. I run 3" studs on the rear and bought a 1/2" hub centric billet spacer from the same guys that sell the wheels. I think they also sell 1/4" spacer. I used cheap auto zone spacers and flat washers to figure out what spacer thickness I would need. The wheels I bought are thick in the center, the 2" studs that came with the Dr Diff hubs barely made it through the lug nuts. I bought 3" studs for the front and swapped them out: http://southwestspeed.com/?sec=view_part&id=24534 I already had 3" studs in the rear.
*I do not have a spacer on the front*
-Michael
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 68cuda440] #1671546
09/16/14 01:58 AM
09/16/14 01:58 AM
SoCal
SoCal
-Michael
Yeah, I've got the 2" stud kit all the way around. I'd hate to swap them out.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 68cuda440] #1671547
09/16/14 02:02 AM
09/16/14 02:02 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
5 x 4.5" bolt pattern A-body conversion axles increase the track 1/4" per side.
Rear rotors increase the track an additional 1/8" per side, for a total assembly width of 58.175".
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671548
09/16/14 02:03 AM
09/16/14 02:03 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
If you look closely at the pictures of the front you can see the studs sticking out. I did not absolutely NEED to swap the studs in the front. For the rear, with a spacer, I do not think you could get away with running 2" studs. It is going to depend on the thickness of the wheels.
-Michael
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671549
09/16/14 02:22 AM
09/16/14 02:22 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can't use an A body Barracuda for reference on a Dart in the rear. Barracudas rear quarters are way more forgiving.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671550
09/16/14 03:19 AM
09/16/14 03:19 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
But have you fit 275/35/18 in the rear with just an offset shackle move? No lip rolling or mini tubbing?
On my 68 Dart, 245/60/15 will rub the stock outer lip and I see rub marks on the top of the inner fender from the body leaning and tipping the tire inward.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: autoxcuda] #1671551
09/16/14 03:41 AM
09/16/14 03:41 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
No, my car got the rear springs moved in on day 2 and the lips rolled on day 3. But the guy with the lime green 71 does run 275's squared. You have to commit to a tire size and go for it. Those little air saws work wonders and so does a block of wood and a sledge.
