Distributor Tear Down #1671473
09/15/14 07:47 PM
09/15/14 07:47 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
So.. working on tuning and don't want to damage the distributor. I am running the following distributor.
http://www.amazon.com/ACCEL-59302-Performance-Replacement-Distributor/dp/B000CIE64Q
I can see the screw heads to adjust the mechanical advance, but I think to do it right I need to pull the reluctor, pickup, etc. to get to the centrifugal advance. What is the proper procedure? I've done some searching, and I'm not exactly sure how to get the reluctor off without damaging it.
Can I remove the pickup without having to re-adjust the pickup-to-reluctor position? It looks like the whole plate comes out as one without having to loosen the pickup plate.
Stock 383, want to give some more initial advance to help with cooling at idle, so need to reduce total mechanical advance. Also, running the vacuum advance. Stock cam in this engine.
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Distributor Tear Down [Re: Crazy68Dart] #1671474
09/15/14 10:48 PM
09/15/14 10:48 PM
If it has externally adjustable slots like the MP Mallory built one does then you would set the initial then adj the slots to get 36 total (initial+slot length). If you have to take off the reluctor and the plate assy to get to the springs/slots like with the old reliable OE dists then you would stick a pair of needlenose pliers down there & expand the vertical tips of the clip as much as you can several times which ain't much then with the reluctor pushed down for maximum clearance down there, grab one of the vertical legs & swing it around the open side & up to get it out of there. When done & going back together set the clip on the rounded nub & on both sides of it push it down till it's in the shaft nub groove then squeeze the ends together with your needlenose pliers several times. they wont go all the way together but get em somewhat closer so the reluctor cannot come up past the rounded nub. also when removeing the reluctor have a helper press down on the center shaft as you lever the reluctor up and off the shaft with 2 screwdrivers then switch to tire irons being carefull not to mar/damage anything. You want the slotted plate to stay on the 2 nubs while the reluctor is being removed all the way off of the shaft. EDIT bend the clip back to normal before reinstallation: circular part flat and even and legs vertical
Re: Distributor Tear Down [Re: RapidRobert] #1671475
09/16/14 09:51 PM
09/16/14 09:51 PM
Canton, Ohio
Canton, Ohio
What do you mean by externally adjustable slots?
Re: Distributor Tear Down [Re: Crazy68Dart] #1671476
09/16/14 10:16 PM
09/16/14 10:16 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
ya , what externally adjustable slots ??? .
You should be able to pry up the reluctor , 2 screwdrivers 180* apart against the housing and under the reluctor , mark it first so you put it back correctly.
Mallory sells a kit with different size spoons to adjust the amount of mechanical advance , I di it but don't remember if I pulled it apart , someone elses engine about 3 years or so ago , I have CRS now ...
Re: Distributor Tear Down [Re: JohnRR] #1671477
09/16/14 10:44 PM
09/16/14 10:44 PM
I was refering to the Mallory system but I ain't never worked one one so I was refering to it as best as I could. Hey double R, I had heard that you were on vacation & that's why I got a bit loose with my nomenclature
Re: Distributor Tear Down [Re: RapidRobert] #1671478
03/09/15 02:34 PM
03/09/15 02:34 PM
Canton, Ohio
Canton, Ohio
Is there a way for me to get the mechanical in the ballpark? I seem to remember a way to measure the gap which would equal the number of degrees of advance.
Thanks.
Re: Distributor Tear Down [Re: Crazy68Dart] #1671479
03/09/15 02:57 PM
03/09/15 02:57 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I think an article at setting up the dist has a lot of good info.
Once on the page, scroll down the list to distributor recurving.
