Page 2 of 3 1 2 3
Re: Who's running a 543 Wedge in a Stock Block? [Re: Monte_Smith] #1671309
09/17/14 02:21 PM
09/17/14 02:21 PM
AndyF Offline
AndyF  Offline
From what I've observed over the years everyone needs to learn this lesson the hard way. A lot of people on here have switched over to aftermarket blocks but usually only after they've blown up a stock block.
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671310
09/17/14 02:27 PM
09/17/14 02:27 PM
Dragula, I had, sold it, a 526 CI motor(4380borex4.375 stroke) in a stock 440 block with ductile iron main caps make over 845 HP on race gas. It was dyno tuned and I ended up melting three pistons on the dyno due to a loose power valve block off plug in the rear carb., I kept leaning all eight barrels down and the motor kept gaining power until it melted those pistonsI didn't pay enough attention to the 8 EGT and AFR from one side of the motor to the other The new owner has not raced that motor yet, he is building a new car, it isn't done yet, he went through a divorce and so on
My message is the larger motor will make more power and strain on the main webbing, buy a good block or keep the power down below 700 HP and shift it before 7500 RPM I've seen several stock blocks, 426 M.W. and 440, break the main webs at or close to 650 HP As Monte said some get away with stock blocks and others have wreck and injured themselves do to block failures while racing, don't take a chance
Re: Who's running a 543 Wedge in a Stock Block? [Re: Cab_Burge] #1671311
09/17/14 03:11 PM
09/17/14 03:11 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
FWIW... We ran a stock block 540 with Program caps, good balancer(ATI) on alcohol. Shift at 7000. Had to be 750+hp as it went 7.90 in a dragster. While freshening, it was discovered that #4 main web was cracked. Got a free pass on that one. Aftermarket blocks aren't cheap. But at least we aren't replacing CNC -1 heads!! or the crank...or the rods...or the pistons...or the pan..you get the idea.
RIP
Re: Who's running a 543 Wedge in a Stock Block? [Re: sc4400] #1671312
09/17/14 04:42 PM
09/17/14 04:42 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
My next purchase will be an aluminum block.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Who's running a 543 Wedge in a Stock Block? [Re: Eric] #1671313
09/17/14 05:52 PM
09/17/14 05:52 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Perhaps they need to become affordable before the LS swap craze makes it into Mopars. But let's be honest, how else can you build a "reliable" 800-1000+ HP for that $?
Re: Who's running a 543 Wedge in a Stock Block? [Re: gregsdart] #1671314
09/17/14 08:35 PM
09/17/14 08:35 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I wouldn't plan a 4.5 stroke in a 440 block for anything beyond about 600 hp, and then only if I had a very light rotating assembly and / or a center weighted crank to help relieve stress on the bottom end combined with small port heads....
At that point, why bother with the long stroke if you're not going after a big HP number? Get a Megablock or other aftermarket block, let it eat, and sleep soundly.
The reasons are budget, what's on hand and the torque range desired.
Well, of course, Greg. But, having a limited budget doesn't trump common sense, and most of all, safety. Like Monte said, you'll never know when the bomb will go off, and if it lets go at the top end, the resulting damage will be a lot more than what an aftermarket block costs.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Who's running a 543 Wedge in a Stock Block? [Re: Charger453] #1671315
09/17/14 08:51 PM
09/17/14 08:51 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
When ever I read these threads I get a sinking felling in my belly. I have been running a 541 in my F.A.S.T car for the past 6 years. I have been using a stock block not because of my budget but because of the rules of the class. Which since have changed. I don't believe many of the faster cars where following the rules to begin with but I was dumb enough too???
It has all very good light weight parts in it and has at least 400 passes on it with no issues. It does come apart after every 50-70 passes and always looks good with the exception of the stock cast iron 286 heads. Every season the heads are out for repair or replacement.
Stock block, factory max wedge heads and intake as well as exhaust manifolds. I shift it at 7,000 and it goes thru the traps at 7,500.
So far so good!
Thanks HP Mike
Re: Who's running a 543 Wedge in a Stock Block? [Re: XXHEMI] #1671316
09/17/14 09:39 PM
09/17/14 09:39 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
So far so good!
Thanks HP Mike
Are you using the stock oil pan pickup?
Crossram intake mods?
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671317
09/17/14 10:34 PM
09/17/14 10:34 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Some interesting replies....So nobody over +700hp stroker in a stock block? According to some on here, ours should have blown up 3 seasons ago...I have no doubt it will eventually let go, but I have a stock block sitting here, so I would like to build a spare.
I'm only running a 4.375 stroker in an RB block but It made 750hp at 6200 on the dyno at 34 degrees total.
I backed the timing down to 30 total since my friends son wanted to drive it and it ran
10.26 @131mph in a 3200# Duster at Vegas. I'm worried about it letting go so I'm looking for a nice aftermarket block as well.
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671318
09/18/14 03:18 AM
09/18/14 03:18 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Here's my buddys "aftermarket" ford block. Kinda made him
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Who's running a 543 Wedge in a Stock Block? [Re: MoParFish] #1671319
09/18/14 03:22 AM
09/18/14 03:22 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Took the rotating assembly out and poor thing just fell apart. Got two nice 4 cylinder wine racks now...
Re: Who's running a 543 Wedge in a Stock Block? [Re: DusterDave] #1671320
09/18/14 08:39 AM
09/18/14 08:39 AM
gregsdart Offline
gregsdart  Offline
Dave, I don't understand the "common sense" comment? I believe we are on the same page. That is, a stock block has its limits. You can only push it so far, then you risk breaking it, and the risk goes up with the stress you put on it like anything else. If a guys budget doesn't have the funds for an aftermarket block, then the build better take the risks into consideration, or the builder better understand the risks.
Increasing the stroke from 3.75 to 4.5 raises the stress on the parts by 44.5 percent. Raising the rpm from 5500 to 6000 multiplies that 44.5 percent by another 20 percent, for a total of 170 percent of the original stress of the 3.75 stroke. If your parts are 40 percent lighter, the whole deal falls back to a two percent increase in stress when you compare a stock weight 3.75 stroke motor to a 4.5 stroke light weight assembly with the rpm limits I talked about. So I see it as apples to apples due to reduced rpm and light parts IF you run it in the right rpm range, and aren't hurting it with a bad tune or nitrous. Most motors can be pushed about 50 percent higher than they were originally designed for. On an old 440 block I wouldn't go that high.
Re: Who's running a 543 Wedge in a Stock Block? [Re: GY3] #1671321
09/18/14 09:02 AM
09/18/14 09:02 AM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
So far so good!
Thanks HP Mike
Yes we do have to run stock oil pan and it still has a stock pickup in it. Mike used chevy rods ends so clearance was a lot less of an issue.
Jon Kasse Racing worked on the intake manifold (Picked up 82 HP).
Pretty much nothing went untouched.
Re: Who's running a 543 Wedge in a Stock Block? [Re: gregsdart] #1671322
09/18/14 12:47 PM
09/18/14 12:47 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
You're right, we are on the same page. Your comment in bold dovetails with my "common sense" phrase, we just word it differently.
Re: Who's running a 543 Wedge in a Stock Block? [Re: DusterDave] #1671323
09/18/14 07:23 PM
09/18/14 07:23 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
DusterDave this was the same think I kept coming back to. I had stupid money in a 400 block. $1500-1800 more would have got me an aluminum block. Had it in the Cuda ready to fire up and I kept coming back to the same conclusion. This thing is not going to last and I could loose all the money I had in the block or worst my Cuda.
So I pulled the engine. I'll swap out the roller for a solid tappet, put on Eddy heads and shift it at 5800-6000 and race sportsman class. The engine will go in my 67 Belvedere wagon. Now to start saving for a better block to put in the Cuda. Some times we are all just knuckle heads. Lol
Ok
Re: Who's running a 543 Wedge in a Stock Block? [Re: cudatom] #1671324
09/18/14 11:31 PM
09/18/14 11:31 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
So would you guys be able to recommend a block that would hold up but looks some what stock? Stock mounts? Must be iron. Or maybe not if it looks stock enough?
Thanks Ed
Re: Who's running a 543 Wedge in a Stock Block? [Re: XXHEMI] #1671325
09/19/14 12:42 AM
09/19/14 12:42 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
One of my friends is running a mega block. He has had this for yrs. I'd say at least 8. The second I believe is running a world block but not sure. Both are mid 9's and the cars weigh around 3500. Neither has had any block related issues.
Ok
Re: Who's running a 543 Wedge in a Stock Block? [Re: cudatom] #1671326
09/19/14 11:33 AM
09/19/14 11:33 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I apoligize for affending so many people by asking who races a stroker RB in a stock block.....I had no idea so many people would get so upset about racing a stroker motor with a stock block....I was just looking for relavent info on anybody who had run one and who's kit they used and what issues they encountered. I will probably still go my way if money allows. From our end we see no issue with it as it is only 1/8th more stroke in either direction than we run now.
And I will mention this about after market blocks that many on here say are the best thing since sliced bread....There are all kinds of issues with those as well. At least with a factory block, I know it will assemble well if all the parts I purchased are good. Aftermarket block not so much, and then you have to start those uncomfortable discussions with them so you can get it fixed....Like who pays for it, who fixes it, who pays for shipping etc...
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671327
09/19/14 12:28 PM
09/19/14 12:28 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Randy, I wasn't offended. I was just offering my opinion, FWIW.
Re: Who's running a 543 Wedge in a Stock Block? [Re: DusterDave] #1671328
09/19/14 12:29 PM
09/19/14 12:29 PM
gregsdart Offline
gregsdart  Offline
Same here. Information is all I care about,,,,,,, I think
Page 2 of 3 1 2 3
