Wheel cylinders. Where's best place to buy originals
#1671263
09/15/14 02:04 PM
09/15/14 02:04 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
I am getting ready to either rebuild my originals or looking to buy original / OEM replacement wheel cylinders for my 70 3/4 ton power wagon. Truck has been sitting for 30 years. I can only get 1 bleeder to work as rest are frozen and I don't want to snap them off.
What is best way to get the bleeder out? Heat? Propane torch? or if you snap them off to easy out them?
thnks,
Wizard
Guns, God, and Country.
U.S. Veteran
Re: Wheel cylinders. Where's best place to buy originals
[Re: Wizard]
#1671264
09/15/14 02:56 PM
09/15/14 02:56 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Just get a set from any good parts store.Only reason for NOS would be a points build.heat they might come loose.But they will still need rebuilt if they arent totally corroded inside.Rocky
Chrysler Firepower
[Re: 76dodgeboy]
#1671268
09/16/14 09:00 AM
09/16/14 09:00 AM
Posts: 1,794 Greer, SC
TooMany62s
Greer, SC
Moog is claimed to be some of the best. I normally buy what I can afford and it works just fine.
Moog is Federal Mogul's chassis brand. Their brake parts brand would be Wagner.
[Re: TooMany62s]
#1671269
09/16/14 09:14 AM
09/16/14 09:14 AM
Wizard
Dillsburg, PA
Okay, thanks for the input. Auto parts store brand it is.
Wizard
U.S. Veteran
[Re: dogdays]
#1671271
09/17/14 04:23 PM
09/17/14 04:23 PM
therocks
Niles , Ohio
Over 30 years in the buisness and Ill tell you that most parts house brands are either wagner or raybestos.Same with a lot of rotors.Cant tell how many were reboxed from name brands to store brand.Rocky
Chrysler Firepower
[Re: therocks]
#1671272
09/19/14 04:39 PM
09/19/14 04:39 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
With patients, you can rebuild your original ones easy enough. A rebuild kit would be much cheaper and you can control the quality. Or else like mentioned, they are available over the counter.
I have mechanical Aptitude. I can screw up anything.
