leaking front band adjuster fix #1671220
09/15/14 12:05 PM
09/15/14 12:05 PM
tennessee,usa
mattsmopars Offline OP
tennessee,usa
I have been having a few issues with leaks on the 727 in my bee.
I had one leak at the selector shaft seal, so I replaced it. Then I had a leak at the front band adjuster. Anyway I found a oil plug seal/gasket at our local GM dealer the part number is 14090908. It was about perfect as far as fit goes slid tightly over the threaded part and seal it off against the lock nut.
Just thought someone else might could use that information in case they had a leak at the front band adjuster.
Matt
Re: leaking front band adjuster fix [Re: mattsmopars] #1671221
09/15/14 12:48 PM
09/15/14 12:48 PM
thanks Matt for the info. I will take note of the #. leaks on the driveway are the cats' ass
