Unwarping door panels #1671132
09/15/14 02:32 AM
09/15/14 02:32 AM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
Anyone have success doing this? All the vinyl is good, and the plastic moisture shields were in place, but 50 years takes it's toll. I saw someone get theirs damp and park their SUV on it overnight. Was thinking something along the lines of that--getting them damp, and placing a flat surface and weight on top. Not a vehicle, though.
Re: Unwarping door panels [Re: 375inStroke] #1671133
09/15/14 04:24 AM
09/15/14 04:24 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
How about wetting them place 2 1/8 sheets of plywood (1 on each side)then place it between your matresses?
-Daty
Re: Unwarping door panels [Re: Daty Rogers] #1671134
09/15/14 03:59 PM
09/15/14 03:59 PM
Seattle, WA
3
3
Seattle, WA
You try that? How did they turn out?
Re: Unwarping door panels [Re: 375inStroke] #1671135
09/17/14 09:25 AM
09/17/14 09:25 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I had great success fixing warped panels by getting them good and damp with a spray bottle and then laying them out on a flat surface (I think I used a towel on a glass sheet (spare window for storm door) which was on a stout table and used flat paver stones to apply even pressure.
Let them dry, in the sun is best and in a few hours presto! If you can a few days is better to make sure they are all dried out.
Not right? Just hit them again. I think I may have even used some aluminum sheet as shims in a few spots to get the panels to go in the direction I wanted.
I used hot glue to secure the vinyl after working out any wrinkles with a heat gun. Just gently pull the vinyl and then apply the glue on the backside. Your fingers will get warm!
Panels looked like new after I was done, very rewarding.
"I think its got a hemi"
Re: Unwarping door panels [Re: gdonovan] #1671136
09/17/14 01:27 PM
09/17/14 01:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've tried a hair dryer on vinyl - and the pattern disappeared. Use caution with heat around the vinyl.
Getting the panels soaking wet ??? Hmm, I have a panel that got soaked - the fiberboard delaminated on every corner. But it wasn't sandwiched between any other panels.
I don't have the solution to flattening the panels but I think I'm going to pull the vinyl off the existing board, make a new board and glue the vinyl back to it.
