Re: V. Gaines Crashes and Walks Away
[Re: McCandlessboy]
#1670934
09/17/14 01:44 PM
09/17/14 01:44 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
There are just to many Tracks that are making plenty of $$$ that will not put out any $$$ to have the track surface fixed.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: PETE@BESTMACHINE]
#1670937
09/18/14 12:42 AM
09/18/14 12:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Monday morning quarterbacks are just great, funny I don't think anybody had any trouble getting down the track at the last race, they must of changed there wing angle between races. Some people think they are smarter than the crews running these cars, what a joke. NHRA made a rule change in 2010, set min weight on rear of car, a little taller wicker height and small chin spoiler.
Well being that you chose me as your target... why did others going down the track right before him say that the track was unsave... your the pro.. do tell
#1670945
09/18/14 11:32 AM
09/18/14 11:32 AM
MR_P_BODY
So Mr [Edited by Moparts - Family Friendly Site - Keep it clean], you must have been there to give you opinion of the race surface being the expert you are with your 42,000 useless posts.
No I wasnt.. but if you would have watched it and LISTENED to the prior people that went down the track even you might have learned something.. as of my 42,000 useless post at least I dont show up and BRAG about the only dyno pull that made decent power.. then not show up again for ages ..... but then again your the PRO know it all... so you have to be right... sorry I even disputed you
#1670947
09/18/14 12:04 PM
09/18/14 12:04 PM
MR_P_BODY
Yes I knew the track was a problem most likely due to weather conditions, to bad about V Gains, Glad he is ok, there is still a lot of good stuff on this site, just not your stuff. Very busy and not enough time to post a lot, we use Facebook for our builds and dyno tests, it is faster with todays phones.
I sure dont know what you have against me but I could care less... because I dont care for you either.. I'm gonna drop it at that
[Re: MRMOPAR622]
#1670949
09/18/14 05:30 PM
09/18/14 05:30 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
There is a SIMPLE fix to the Pro-Stockers "skating" around......Put some damn WING in the car. It is just so much easier to blame the track than to put enough wing in it to NOT be on the ragged edge of crashing because it might slow you down a hundredth. If a 10,000hp fueler can stay stuck, the track AIN'T THAT BAD.
Always the Pro-Stock guys complaining about track prep because they REFUSE to put wing in the cars
Monte
Monte,when you put that 1100 hp engine in your car even with out the NOS then you will understand after you make a few pass's!
Not sure what that means.....but OK. I have been faster in the 1/4 in a door car than current pro-stocks are by a bunch. And I know how much difference "just a little" wing can make from something being literally undriveable to going right down. Prep and conditions will NOT be the same from track to track, nor event to event at same track. So thinking that you may not have to change something on the car.........well that makes no sense.
Now if water was coming up, that is a totally different deal. My comments were based on the cries of "that track is junk and should be dug up"..........really? This is a multi million dollar facility. Do you really think if there was a problem with the surface that NHRA thought needed addressing, that Bruton wouldn't fix it......cmon.
As far as the Pro-Stock guys talking about the surface being bad.......they do it ALL the time at various tracks when it doesn't have as much top end grip as they would like. It's nothing new.
Monte
[Re: pittsburghracer]
#1670951
09/18/14 06:31 PM
09/18/14 06:31 PM
Posts: 2,525 Louisville, KY
E-Ticket
Louisville, KY
Monte did you watch the race on TV? The track was lifting up and even the top fuel guys were afraid to race on it. The concrete was lifting up "big-time" and in the interview they commented on it cutting a slick and taking the wing out. I was racing over the weekend so I didn't watch it till last night. That track NEEDS FIXED.
Once again....EXACTLY! They were holding pieces of the track in their "hand" talking about how dangerous it would be for the fuel cars if they were to get a piece of the track and cut down a tire...... It was there on TV for God and everyone to hear and see.......
[Re: Monte_Smith]
#1670952
09/19/14 02:31 PM
09/19/14 02:31 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I have been faster in the 1/4 in a door car than current pro-stocks are by a bunch. Monte
Monte, If you did go faster than a current prostock car, my guess would be a promod. So then we have no clutchless 5 speed, no rear weight rule, no wing/body rule, and no tire rule. Given the current pro mods they have wings the size of billboards, weight wherever they need it and a minumum of a 34.5 tire. So whatever car you drove cannot compare to a current prostock.
I have heard the problem with the track is the concrete is cracking off in pieces from the mix being wrong. This is not the first time this has happened. but what do i know
BB, TT5,Procharged 3300lb Street Car 4.79/154
