Degree help needed ASAP
#1670875
09/14/14 03:04 PM
09/14/14 03:04 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Buddies trying to install my new bullet cam in my A8 block and is having trouble with the install. Anyone can help please let me know ASAP. Georgia is a week away.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Degree help needed ASAP
[Re: W8n2DustU]
#1670876
09/14/14 03:20 PM
09/14/14 03:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I set the crank at the number you want(as in 108) and then set the lifter to the max then slide on the gears then check it at the valve and move it if needed
[Re: MR_P_BODY]
#1670877
09/14/14 03:33 PM
09/14/14 03:33 PM
W8n2DustU
San Angelo, Texas
Can you call Frank @ 432-553-0214. I will owe you one.
[Re: W8n2DustU]
#1670878
09/14/14 03:54 PM
09/14/14 03:54 PM
MR_P_BODY
I talked with him... he should be set
[Re: MR_P_BODY]
#1670879
09/14/14 07:52 PM
09/14/14 07:52 PM
W8n2DustU
San Angelo, Texas
I really appreciate your help. Thanks again. I owe you one.
[Re: W8n2DustU]
#1670880
09/14/14 07:57 PM
09/14/14 07:57 PM
MR_P_BODY
Marty... shoot me a PM.. I want to talk with you about something
[Re: MR_P_BODY]
#1670881
09/14/14 11:35 PM
09/14/14 11:35 PM
W8n2DustU
San Angelo, Texas
[Re: MR_P_BODY]
#1670883
09/15/14 12:04 AM
09/15/14 12:04 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That is like a duh! Why didn't I think of that way to get right in the ballpark first time sprocket goes on. Gonna do that on my 6.1 in a couple weeks.
Mopar to the bone!!!
[Re: 72Swinger]
#1670884
09/15/14 12:09 AM
09/15/14 12:09 AM
MR_P_BODY
The guy was playing with a gear drive so they dont run any dots... thats the same that I run(gear drive) and I found that the easiest way
[Re: MR_P_BODY]
#1670885
09/15/14 01:25 AM
09/15/14 01:25 AM
72Swinger
Nebraska
Yeah even with dots you could do what you said and still save a bunch time. Like those 9 key way crank sprockets, ive had to spend HOURS trying to get those to come in 2-3 degrees advanced.
[Re: 72Swinger]
#1670886
09/15/14 01:58 AM
09/15/14 01:58 AM
MR_P_BODY
When the guy called me back he said he was within a 1/2 and 1 degree on the first shot.. he was happy... he had others telling him all sorts of stuff of setting it at 119 as setting the cam at something... he was lost
