Degree help needed ASAP #1670875
09/14/14 03:04 PM
09/14/14 03:04 PM
San Angelo, Texas
W8n2DustU Offline OP
San Angelo, Texas
Buddies trying to install my new bullet cam in my A8 block and is having trouble with the install. Anyone can help please let me know ASAP. Georgia is a week away.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Degree help needed ASAP [Re: W8n2DustU] #1670876
09/14/14 03:20 PM
09/14/14 03:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I set the crank at the number you want(as in 108) and
then set the lifter to the max then slide on the gears
then check it at the valve and move it if needed
Re: Degree help needed ASAP [Re: MR_P_BODY] #1670877
09/14/14 03:33 PM
09/14/14 03:33 PM
San Angelo, Texas
San Angelo, Texas
Can you call Frank @ 432-553-0214. I will owe you one.
Re: Degree help needed ASAP [Re: W8n2DustU] #1670878
09/14/14 03:54 PM
09/14/14 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I talked with him... he should be set
Re: Degree help needed ASAP [Re: MR_P_BODY] #1670879
09/14/14 07:52 PM
09/14/14 07:52 PM
San Angelo, Texas
San Angelo, Texas
I really appreciate your help. Thanks again. I owe you one.
Re: Degree help needed ASAP [Re: W8n2DustU] #1670880
09/14/14 07:57 PM
09/14/14 07:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Marty... shoot me a PM.. I want to talk with you about something
Re: Degree help needed ASAP [Re: MR_P_BODY] #1670881
09/14/14 11:35 PM
09/14/14 11:35 PM
San Angelo, Texas
San Angelo, Texas
Done!
Re: Degree help needed ASAP [Re: W8n2DustU] #1670882
09/14/14 11:59 PM
09/14/14 11:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks... I PMed you back... maybe I should have sent
you my phone number
Re: Degree help needed ASAP [Re: MR_P_BODY] #1670883
09/15/14 12:04 AM
09/15/14 12:04 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is like a duh! Why didn't I think of that way to get right in the ballpark first time sprocket goes on. Gonna do that on my 6.1 in a couple weeks.
Mopar to the bone!!!
Re: Degree help needed ASAP [Re: 72Swinger] #1670884
09/15/14 12:09 AM
09/15/14 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The guy was playing with a gear drive so they dont
run any dots... thats the same that I run(gear drive)
and I found that the easiest way
Re: Degree help needed ASAP [Re: MR_P_BODY] #1670885
09/15/14 01:25 AM
09/15/14 01:25 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yeah even with dots you could do what you said and still save a bunch time. Like those 9 key way crank sprockets, ive had to spend HOURS trying to get those to come in 2-3 degrees advanced.
Re: Degree help needed ASAP [Re: 72Swinger] #1670886
09/15/14 01:58 AM
09/15/14 01:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When the guy called me back he said he was within
a 1/2 and 1 degree on the first shot.. he was happy...
he had others telling him all sorts of stuff of setting
it at 119 as setting the cam at something... he was
lost
