indy aluminum block #1670632
09/13/14 06:15 PM
09/13/14 06:15 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I have a Indy Maxx aluminum block and I would like to know the main cap and cylinder head torque numbers if you know , thanks in advance .
Re: indy aluminum block [Re: robnbird] #1670633
09/13/14 07:31 PM
09/13/14 07:31 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the main stud torque is stamped on the bottom of the block in the corner. Head studs/bolts go by what you are using
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: indy aluminum block [Re: robnbird] #1670634
09/13/14 08:30 PM
09/13/14 08:30 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
90lbs on the vertical caps, 80lbs on the horizontal. ARP head studs we do at 75lbs.
Re: indy aluminum block [Re: rebel] #1670635
09/13/14 09:58 PM
09/13/14 09:58 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Re: indy aluminum block [Re: rebel] #1670636
09/13/14 10:24 PM
09/13/14 10:24 PM
NC
440Jim Offline
440Jim  Offline
NC
Do the head studs go into the block ~1" (like an iron block) or do you use other studs to get more threads in the aluminum block?
Re: indy aluminum block [Re: 440Jim] #1670637
09/13/14 11:24 PM
09/13/14 11:24 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
they use the same studs as you've shown Jim, i just measured the holes in my block & they seem to average out at 0.995-0.998 deep. it's the 0.900 end that goes into the block, not the 1.000 end.
Re: indy aluminum block [Re: rebel] #1670638
09/15/14 09:38 PM
09/15/14 09:38 PM
NC
440Jim Offline
440Jim  Offline
NC
Just to be clear, it depends if you measure the coarse thread to the end of the threads or the bevel (.9 to 1.0).
I asked because the KB block has studs with about 1.75" on the coarse end. But the block has a counterbore about 0.25" and the studs have a small stand off on the end, so less than 1.75" is engaged in the block threads but much more than 1"
