Valve Cover Breathers-What is NHRA acceptable? #1670610
09/13/14 05:04 PM
09/13/14 05:04 PM
HR3128 Offline OP
HR3128  Offline OP
I have to add some breathers to valve covers. Are the old standard rubber grommet push-in style Valve cover breathers acceptable by NHRA Tech guys? I thought they were not. I took a quick look at the NHRA rule book and did not see anything about valve cover breathers. What are you guys using?
Re: Valve Cover Breathers-What is NHRA acceptable? [Re: HR3128] #1670611
09/13/14 05:14 PM
09/13/14 05:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What ET are you planning on... I believe sub 10.0
they wanted locked on ones
Re: Valve Cover Breathers-What is NHRA acceptable? [Re: MR_P_BODY] #1670612
09/13/14 05:22 PM
09/13/14 05:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
never seen them check them so unless you are at a division or national event don't worry
Re: Valve Cover Breathers-What is NHRA acceptable? [Re: Quicktree] #1670613
09/13/14 05:58 PM
09/13/14 05:58 PM
HR3128 Offline OP
HR3128  Offline OP
NHRA Super Street-IHRA Hot Rod 10.90. I think the car will be able to run about a sec quicker. I would like to go to some divisional events.
Re: Valve Cover Breathers-What is NHRA acceptable? [Re: HR3128] #1670614
09/13/14 06:29 PM
09/13/14 06:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would not suggest just a push in breather, you need something in addition to the grommet to keep it in there.
Re: Valve Cover Breathers-What is NHRA acceptable? [Re: Challenger 1] #1670615
09/14/14 12:47 PM
09/14/14 12:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went with the bolt on,I have blown the push on type off a few times
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
