Drag radial air pressure
#1670519
09/13/14 11:04 AM
09/13/14 11:04 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Stock suspension A body Intermittently spins on the hit. Running 19 pounds. Go up or down? Car went 1,66, 1.65, then 1.79 in elims last night. Same technique, leave at 1500 off foot.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Drag radial air pressure
[Re: justinp61]
#1670521
09/13/14 01:42 PM
09/13/14 01:42 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
What Drag Radials are you referring to Street Drag Radials or Slicks Drag Radials?On my Street Legal Nitto's 305 Drag Radials I run 18 lbs last time next time I get the chance(plan on going to a T&T) I will lower the air pressure by a 1/2 pound at a time to see if it helps.A trick I have found on my Street Drag Radials is they will hook better if I put put 10-15 miles of hi-way driving on them and get them good & Hot. PS With the Street Legal Drag Radials it is more important to have the correct rim width than with a slick.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1670522
09/13/14 03:06 PM
09/13/14 03:06 PM
B3422W5
Portage,michigan
It's a Hoosier drag radial/ slick. Just two grooves. Lowered to 17.5 from 19. Moved laugh rpm up 500 rpm and netted personal best in this car 11.84 with 1.65 60 foot. Gonna leave it alone and see I can get some consistency now
[Re: B3422W5]
#1670523
09/13/14 06:00 PM
09/13/14 06:00 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I worked my way down fro 22 to 17-18 in my 325's last time out, seemed to work good.
Might head to to Milan tomorrow for some T&T...going to try out a 950 and going to play with timing
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: fishy340]
#1670525
09/15/14 02:48 AM
09/15/14 02:48 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run my 255 M/T's at 18 lbs. 1.63 short time is what I typically see on a good run.
[Re: StealthWedge67]
#1670526
09/15/14 02:54 AM
09/15/14 02:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Every car will want something different... if you have 2000 lbs on the back it WILL take more pressure to hold the same surface area... vs 800 lbs on the back
[Re: MR_P_BODY]
#1670527
09/15/14 12:28 PM
09/15/14 12:28 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I had 17 in mine when it went on the bumper at monster mopar. And like Andy said you can go to most x275 or ultra teams and they will be in the 17-18 psi range. It doesn't seem the stiff side walls care about how much you car weights.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: plasticfantastic]
#1670529
09/15/14 02:41 PM
09/15/14 02:41 PM
B3422W5
Portage,michigan
I managed to get the 60 ft as good as 1.639 with air at 17.5 pounds, which is good for a heavy 11.80 car basically, but it's far from repeatable pass after pass. Car has currently a big rake to it( 24 inch tall tires that were on the front when I bought it).And battery is still in front. Gonna put 26 inch tire on front and move battery over winter. With low power of car, I get the feeling rear tire is kind of skidding and not planting well. The above stuff should help, but might need better shocks too.
[Re: B3422W5]
#1670530
09/15/14 04:10 PM
09/15/14 04:10 PM
Posts: 1,178 Indy
FlyFish
Indy
Yup, I would start working on the suspension...my car is going 1.43's now on that same Hoosier drag radial tire with 18-19 psi and repeats like a broken record.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1670531
09/16/14 11:28 AM
09/16/14 11:28 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
18# in mine. Went 1.12-60' @ 3508#. Just got 100# out of the car.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
