Hotchkis UCA Rod End Dust Boots Installation #1670411
09/12/14 09:25 PM
09/12/14 09:25 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
What's the best or proper way to install the rod end dust boots for my UCA? I heard they're a PIA to put on and, if not careful, can tear. I noticed it came with some grease.
Re: Hotchkis UCA Rod End Dust Boots Installation [Re: MuuMuu101] #1670412
09/12/14 09:31 PM
09/12/14 09:31 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
I stretch out the holes a bit with some spreading pliers to get the rubber a bit flexible, lube them up and go at it. I run the threaded portion in through one of the "side" holes, and then get the rest over the head. Have fun!
Re: Hotchkis UCA Rod End Dust Boots Installation [Re: Dan@Hotchkis] #1670413
09/12/14 09:56 PM
09/12/14 09:56 PM
SoCal
SoCal
I just did this. Took some needle nose pliers and strectched the holes a little. Applied some grease to the boot openings and squeezed it through. I took a little chunk out of one of the side openings (it split slightly) but it doesn't seem like a big of a tear that it would let gunk in. 3 more to go...
Re: Hotchkis UCA Rod End Dust Boots Installation [Re: MuuMuu101] #1670414
09/12/14 10:15 PM
09/12/14 10:15 PM
SoCal
SoCal
Second one went on pretty easily with no tear. Spent extra time stretching the boot hole and then I used my needle nose to pull the boot over the rod end.
Update: Yeah, if you spend the time stretching out the rubber they become super easy. The last 3 had no tears.
