sheet metal sound deadener #1670322
09/12/14 03:23 PM
09/12/14 03:23 PM
CheddarHead till October
weedlayer Offline OP
What to use to stop the banging noise of the sheet metal between the wheel tubs? Everything seems to be foil faced. Any one piece black or dark blue sound deadeners out there. What I see that is black has to go over the foil face. 2 layers, more weight, hope the one sticks to the other
more info: it's not noise coming thru the sheet metal, it's the noise from the sheet metal. Vibrates from exhaust, kinda bangs like a bass drum, etc.
Re: sheet metal sound deadener [Re: weedlayer] #1670323
09/12/14 04:32 PM
09/12/14 04:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A lot of guys just run black carpet.. if its that
bad you could put the bubble style sound deadener
under the carpet(just light weight carpet)
Re: sheet metal sound deadener [Re: weedlayer] #1670324
09/12/14 06:34 PM
09/12/14 06:34 PM
ohio
bigblockrik Offline
bigblockrik  Offline
ohio
Dynamat has a black sound deadener out now.
