Blocking heat crossover on a 440 #1669956
09/11/14 12:47 AM
09/11/14 12:47 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am in the process of having my stock 440 six pack motor rebuilt. The cast iron intake manifold is quite discolored where the heat crossover passage is. I would like to know if it would be O.K. to block the crossover off so that after I repaint the intake it won't discolor.
Re: Blocking heat crossover on a 440 [Re: 440mopar] #1669957
09/11/14 12:56 AM
09/11/14 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont run a carb that uses the heat for the choke
then its no problem... put a piece of metal in it
so the gasket seals it(some thinner SS)
EDIT
When I did it years ago I used high temp rtv on the head
side to seal it then the gasket to hold it in place..
worked fine
Re: Blocking heat crossover on a 440 [Re: MR_P_BODY] #1669958
09/11/14 01:01 AM
09/11/14 01:01 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
It has the factory choke on it but I typically don't drive the car during the cold weather months. Does anyone sell a valley pan designed for blocking off the crossover?
Re: Blocking heat crossover on a 440 [Re: MR_P_BODY] #1669959
09/11/14 01:05 AM
09/11/14 01:05 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If your engine is truly "stock" and you block it the choke won't work any more.
If you run a carb with an electric choke, or feel you don't need a choke at all, then by all means, block away.
The best way IMO is to just use one of the valley pans with the holes already blocked. Mr Gasket, MP, and others sell them both ways--open and blocked. Other guys have used little pieces of tin or whatever to block them, but be careful. Too thick and they can push your manifold up an cause a vacuum/oil leak. To thin and they can burn through.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Blocking heat crossover on a 440 [Re: 440mopar] #1669960
09/11/14 01:19 AM
09/11/14 01:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they do now days... most of the companies do
Re: Blocking heat crossover on a 440 [Re: MR_P_BODY] #1669961
09/11/14 09:08 AM
09/11/14 09:08 AM
gregsdart Online content
gregsdart  Online Content
A small thin (.015?) piece of stainless will do the job as well. Years ago I bought intake gaskets that came with a piece made to put between the gasket and head, worked just fine.
Re: Blocking heat crossover on a 440 [Re: gregsdart] #1669962
09/11/14 09:11 AM
09/11/14 09:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can also use a piece of you old intake to block off the wells. The pan gaskets w/ the block-offs are more expensive. FWIW chokes are over rated. It's not like you are going to be driving the car in 30* weather.
Coming soon!!!!
Re: Blocking heat crossover on a 440 [Re: 440mopar] #1669963
09/11/14 11:38 AM
09/11/14 11:38 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
http://www.summitracing.com/parts/fel-1215/overview/
Not that expensive considering that unless it is cracked it can usually be reused. Do not use the paper gaskets that come with it. They are too thick. Mopar didn't use paper and neither do I unless it just doesn't fit good enough to seal. If you must use the paper buy the thinner .015 thick gaskets from a couple of other sources.
I think someone here did an electric choke conversion on a sixpack some years ago. I don't remember how it turned out or who did it. There isn't anything that just bolts on.
Re: Blocking heat crossover on a 440 [Re: Mr.Yuck] #1669964
09/11/14 11:45 AM
09/11/14 11:45 AM
GomangoCuda Offline
GomangoCuda  Offline
Maybe not in Maryland but in Michigan 30 degrees is called Spring.
Re: Blocking heat crossover on a 440 [Re: GomangoCuda] #1669965
09/11/14 12:08 PM
09/11/14 12:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ha! Used an old fashion pull choke. I have one on this car. In any event a six pack that's been sitting will require ample cranking to get fired.... I pull the choke about 3/4 fire it and opn it full w/in about 5 seconds... (in colder weather)
Re: Blocking heat crossover on a 440 [Re: 440mopar] #1669966
09/11/14 01:18 PM
09/11/14 01:18 PM
an8sec70cuda Offline
Get the valley pan that already has the crossover holes blocked.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Blocking heat crossover on a 440 [Re: an8sec70cuda] #1669967
09/11/14 05:44 PM
09/11/14 05:44 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I got my gasket from Jeg's with free shipping
Re: Blocking heat crossover on a 440 [Re: 440mopar] #1669968
09/11/14 08:57 PM
09/11/14 08:57 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Fel Pro #1215 is what you seek.
Nautilus Racing-
