Page 3 of 4 1 2 3 4
Re: Spark plug heat range?? [Re: hemi-itis] #1669681
09/16/14 01:34 AM
09/16/14 01:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Iron heads,iron block best pass @ 10lbs was 9.907 @140 mph at 35*.
That sure sounds like a lot of timing on 10# specially
with iron heads
Re: Spark plug heat range?? [Re: MR_P_BODY] #1669682
09/16/14 12:59 PM
09/16/14 12:59 PM
Great Neck,LI,new york
hemi-itis Offline OP
with iron heads
If the carbs were too fat,increasing the timing would clean the plugs up to a certain extent.Went from 32*,to 35* and then 37*.to get the plugs you see at the top of the thread. 37* the e/t & MPH fell off but the plug looked the best. I will try a set of 7's and go from there
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Spark plug heat range?? [Re: hemi-itis] #1669683
09/16/14 02:33 PM
09/16/14 02:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
with iron heads
Sounds like you better start working on the cruise
A/F ratio then pull some timing
Re: Spark plug heat range?? [Re: MR_P_BODY] #1669684
09/16/14 03:51 PM
09/16/14 03:51 PM
Agreed Mr P, I want to try the hotter plug 1st and then work on leaning it some
I did get my new best 60,e/t & MPH with the 8's and 35* of timing. I know there more there,I just have to find it
Re: Spark plug heat range?? [Re: hemi-itis] #1669685
09/16/14 03:59 PM
09/16/14 03:59 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
If you REALLY want to read the plug you need to do the following...
1) Make a full pass and click it off at the finish.
2) Tow it back and pull all 8 plugs out.
Trying to read fuel from plugs that have been at anything else but WOT can be misleading.
You CAN read timing from a plug that's been idled afterwards though because the idle temp is much lower then the WOT temp, so the cadmium on the NGK's won't burn back any further.
Those plugs look like they have a touch too much timing in them, but keep in mind that the timing "mark" can be different for any given motor for any given plug range.
As an example I ran a -10 plug on my iron headed turbo car last year. 9:1 compression at 20psi. What's funny is that when it "caved" in the pistons (too much power/heat for a off the shelf slug), the timing mark was just BARELY showing on the tip (no signs of detonation either). What that tells me is if you have too cold of a plug in it, you can fool yourself into trying to read timing from the plug.
What the pictures of your plug do tell me is that you have more then enough octane for what you're running (lots of timing shown on the strap, without any detonation signs).
Not to say I ignore the plugs, but now I read the plug for signs of problems (burn too far on the electrode (excessive timing), and or signs of detonation), but mainly I tune off 1/8mph.
I try not to tune off 1/4mph because it's well above the peak TQ RPM by that point. If you keep tuning for high RPM (1/4 mile MPH), you can hurt the motor with too much timing through the mid range. If it's going to detonate... it's going to do it at peak TQ.
I approach tuning my Turbo car like this.
1) Start low on boost with conservative timing.
2) Get the fuel right.
3) Conservatively rough in the timing. Add some and watch the 1/8mph. Best 1/8mph timing minus 2~4 at this boost level. This will give you a pretty good idea how much deg/boost you need to pull out for a safe attempt at more boost.
4) Add boost and make sure that the fuel still looks good.
5) ONLY THEN add timing.
Sounds like you skipped right to step 5... lol I would take a bit of timing out of it. Tune the fuel until you get the 1/8mph optimized, then sneak the timing back in it.
In this case you've been very lucky that you have enough octane to cover the boost/compression/timing you've tried. On a more aggressive setup the tuning window can be MUCH smaller.
Good luck with the tuning, hope some of that helped you!
Re: Spark plug heat range?? [Re: hemi-itis] #1669686
09/17/14 12:53 AM
09/17/14 12:53 AM
Looking forward to trying the 7's with no other changes
Re: Spark plug heat range?? [Re: hemi-itis] #1669687
09/17/14 01:55 AM
09/17/14 01:55 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
That's too much advance! I suggest going no more than 30º.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Spark plug heat range?? [Re: hemi-itis] #1669688
09/17/14 02:31 AM
09/17/14 02:31 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No blower expert but those 7`s may be too hot for ya.................
Re: Spark plug heat range?? [Re: Thumperdart] #1669689
09/19/14 11:53 AM
09/19/14 11:53 AM
Spoke with Patrick at Pro systems,he said try the 7's with no other changes and go from there.
Every thing I read points to lower timing,I need to get to a track rental!!!
Re: Spark plug heat range?? [Re: hemi-itis] #1669690
09/19/14 12:25 PM
09/19/14 12:25 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I hope he was able to provide more info than that!
Re: Spark plug heat range?? [Re: Clanton] #1669691
09/19/14 01:48 PM
09/19/14 01:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m w/you but hopefully it gets the results you`re after.........
Re: Spark plug heat range?? [Re: Clanton] #1669692
09/20/14 12:35 AM
09/20/14 12:35 AM
Pat said to take some timing out and try the 7's.I don't know when I can get back to the track,so I have to hit the "spot" for some plug readings.
Thanks Dizuster,your right,,,,,,kinds jumped to 5
Re: Spark plug heat range?? [Re: DusterDave] #1669693
09/20/14 12:38 AM
09/20/14 12:38 AM
Dave,the thing woke the eff up @35*,I will back it down to 32 with the hotter plug and see what it looks like
Re: Spark plug heat range?? [Re: hemi-itis] #1669694
09/20/14 10:26 AM
09/20/14 10:26 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You may want to think about making more cylinder pressure by advancing the cam or...I hope you get things going how you like soon.Good luck!
Re: Spark plug heat range?? *DELETED* [Re: hemi-itis] #1669695
09/20/14 11:15 AM
09/20/14 11:15 AM
johnmilner Offline
johnmilner  Offline
Post deleted by johnmilner
Re: Spark plug heat range?? [Re: johnmilner] #1669696
09/20/14 11:16 AM
09/20/14 11:16 AM
johnmilner Offline
johnmilner  Offline
Re: Spark plug heat range?? [Re: johnmilner] #1669697
09/21/14 01:09 AM
09/21/14 01:09 AM
http://www.wallaceracing.com/plug-reading-lm.html
Thanks for reminding me of those pictures
Put the 7's in and dropped boost for pump gas and went to a car show today in Lido Beach.It was 35 miles round trip.
Did not have a chance to pull any plugs,curious to see if they cleaned up in the cruze mode
Re: Spark plug heat range?? [Re: hemi-itis] #1669698
09/21/14 01:46 AM
09/21/14 01:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dis agree with the Wallace on the plugs... they
say the timing isnt read on the ground strap... I
dis agree... and if you want to see another link
that shows what I'm saying I will... pretty sure most
on here know or hear of 4secondsflat
http://www.4secondsflat.com/Spark_plug_reading.html
Re: Spark plug heat range?? [Re: MR_P_BODY] #1669699
09/21/14 02:38 AM
09/21/14 02:38 AM
Ok,,,,,,,,,,,,,so which chart is correct???????
Re: Spark plug heat range?? [Re: hemi-itis] #1669700
09/21/14 10:21 AM
09/21/14 10:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have always done the timing on the ground strap..
I can change timing and in a few runs see the difference
on the strap... but this is my OPINION but I have
seen the effects
EDIT
This is who wrote the timing article and the pics
for the Wallace site
Thanks to Larry Meaux of Meaux Racing for providing this information and pictures.
(I did a copy/paste on the name from the Wallace site
Page 3 of 4 1 2 3 4
