Indy Maxx Block rear main seal #1669097
09/08/14 08:02 PM
09/08/14 08:02 PM
Real North Cal.
66er Offline OP
66er  Offline OP
Real North Cal.
I have a small leak at the rear of my motor. It's a new build with an Indy Maxx Block. My question is: Does the Indy block take a standard main seal, or am I supposed to buy an special seal from Indy. The seal and side o-rings seamed to go in perfectly. Any help/special tricks would be very much appreciated.
Re: Indy Maxx Block rear main seal [Re: 66er] #1669098
09/09/14 11:56 AM
09/09/14 11:56 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
It takes a std. rear seal. I take a fine file and round the corners of the block slightly so it will not knick or shave the o-ring matl. A dab of silicone on the parting lines and you should be good.
Re: Indy Maxx Block rear main seal [Re: fbs63] #1669099
09/09/14 12:02 PM
09/09/14 12:02 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Are you using a vacuum pump?
Re: Indy Maxx Block rear main seal [Re: fbs63] #1669100
09/10/14 04:00 PM
09/10/14 04:00 PM
Real North Cal.
66er Offline OP
66er  Offline OP
Real North Cal.
Thanks for the reply. This is pretty much how I did it, except for rounding the corners. I'll try that when I replace the seal
Re: Indy Maxx Block rear main seal [Re: Mopar-Al] #1669101
09/10/14 04:05 PM
09/10/14 04:05 PM
Real North Cal.
66er Offline OP
66er  Offline OP
Real North Cal.
No vacuum pump yet. I have the pan evac through the headers. It worked well with my other engine(which was the same ci., cam, and comp ratio).
Re: Indy Maxx Block rear main seal [Re: 66er] #1669102
09/12/14 01:56 AM
09/12/14 01:56 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i gave up on the "O" ring chord that seals the sides on mine. i found that the "O" ring chord was shrinking back over time since it gets stretched when installing. 3Bond the base & sides & it's been leak free everytime now.
Re: Indy Maxx Block rear main seal [Re: rebel] #1669103
09/12/14 05:01 AM
09/12/14 05:01 AM
Arizona
Chris'sBarracuda Offline
Arizona
I've never used any type of o-ring on the rear main.. Didn't know they even had one..
Always used "Right Stuff" and the red Fel Pro seal and called it good.
Chris..
