Page 2 of 6 1 2 3 4 5 6
Re: For The Guys That Follow Drag Week [Re: 85_Ram_4speed] #1668857
09/09/14 09:29 AM
09/09/14 09:29 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
OH NO!, Just got up this morning to see Mike Crow's Dart hit a deer. Tragic indeed, hope everyone is ok though.
That sucks...love that stick shift Dart.
Re: For The Guys That Follow Drag Week [Re: 85_Ram_4speed] #1668858
09/09/14 10:35 AM
09/09/14 10:35 AM
MR_P_BODY Offline OP
Seen this also.... BUMMER.. he had a real pretty Dart
Re: For The Guys That Follow Drag Week [Re: Quicktree] #1668859
09/09/14 02:43 PM
09/09/14 02:43 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Elvis ran 8.81
Did he ever get the EFI on it? I saw some FB updates that he was converting it over.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: For The Guys That Follow Drag Week [Re: MR_P_BODY] #1668860
09/09/14 02:59 PM
09/09/14 02:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
EDIT
Lutz ran a 6.89 at 168 mph with the chutes out
Bailey ran a 6.52 at 226 mph
That's insane. Cubic $$$$$.
Re: For The Guys That Follow Drag Week [Re: 85_Ram_4speed] #1668861
09/09/14 03:14 PM
09/09/14 03:14 PM
BPE Offline
BPE  Offline
That sucks!! He just bought a rotating assembly from me and got the engine together in a very short period of time, just for Drag Week. Hope everyone is ok.
Rod
Re: For The Guys That Follow Drag Week [Re: BPE] #1668862
09/09/14 03:41 PM
09/09/14 03:41 PM
Rod
I was suprized that I hear he was running a 59* block,
I thought he was running a 48* last year with the W-9s..
also heard he couldnt run in the SB class... too many
cubes.. I hear that 425 or 427 is the max for the SB class..
he had a rough way to go this year... BUMMER
Re: For The Guys That Follow Drag Week [Re: MR_P_BODY] #1668863
09/09/14 03:49 PM
09/09/14 03:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
Larson Goes 6.70@218, 4.46@177 to half track. 60 and 1/8th numbers are both slower than his 6.99 run yesterday where he lifted early.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: For The Guys That Follow Drag Week [Re: Triple Threat] #1668864
09/09/14 04:12 PM
09/09/14 04:12 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: For The Guys That Follow Drag Week [Re: OUTLAWD] #1668865
09/09/14 09:28 PM
09/09/14 09:28 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Elvis ran 8.81
Yes. A friend of mine told me that they look like LS1 TBs.
Re: For The Guys That Follow Drag Week [Re: forphorty] #1668866
09/09/14 10:07 PM
09/09/14 10:07 PM
Bailey is out... busted a head and the block.. bummer
Re: For The Guys That Follow Drag Week [Re: MR_P_BODY] #1668867
09/09/14 11:48 PM
09/09/14 11:48 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Bailey is always on borrowed time w/that car!! Jeff tried to run it a cpl years ago & it was a mess then. Hope he can keep his car together & make some more good #'s. Lutz all the way hopefully this year. Guy works hard & plays even harder. Lots of jealous people out there talk junk here on the internet. If they even had a clue or knew the man/family they would think & talk a different tune.
See ya, Ken Michalik
Re: For The Guys That Follow Drag Week [Re: 1974 474 Duster] #1668868
09/10/14 02:03 AM
09/10/14 02:03 AM
In a house near you
Street Monkies Offline
In a house near you
Elvis went 9.04 @ 151 to finish day 2 which he claims was a "soft" pass. 300+ mile road trip to next track. He has the EFI setup on It and and he says 2nd pass with the EFI, just gonna sneak up on it. I think It's down on power from the carbs and so do some others. He still is crushing the class he is running pretty good I believe. Haven't seen any point status though.
Re: For The Guys That Follow Drag Week [Re: Street Monkies] #1668869
09/10/14 02:29 AM
09/10/14 02:29 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Eddie is not down on power...........he has the timing pretty soft and it struck the tires today and his 60ft was 12 numbers off from the 8.80 pass.
It has two 90mm drive by wire GM throttle bodies on it with the Holley EFI.
It has only 3 track passes on it with a new system and running .80s.................not bad
Monte
Re: For The Guys That Follow Drag Week [Re: Monte_Smith] #1668870
09/10/14 02:40 AM
09/10/14 02:40 AM
In a house near you
In a house near you
Hopefully I can see some video coverage of the car actually run and not go off of hear say.. I'll be interested to see what It does with some more passes and better air. Plus a good hooking track always helps. Will see If he can run any quicker then last years best of 8.58 @ 159 mph. I don't think he will beat last years average of 8.68 et.
Re: For The Guys That Follow Drag Week [Re: 1974 474 Duster] #1668871
09/10/14 02:40 AM
09/10/14 02:40 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That car has been totally redone since Jeff tried to run it for Terzich. New motor, new wiring, new system. It was pretty trouble free last year and had a 6.70 average for the week. I would hardly call that borrowed time. The issue this year is just parts failure. It cracked a head through the bolt hole and into combustion chamber. No way to weld it. I left before they found the issue with block, but it is probably a cracked main web. That car still has a cast block and heads.........time for billet......LOL!!!
They are not really leaning on it at only 30lbs of boost. With a billet block, heads and 50lbs of boost, it would be much faster.
Jeff pushed a head gasket today. They fixed it and made a couple more passes. Saw them on the side of the road though and it was running hot. He thinks the pushed gasket may have collapsed radiator inside. Not sure what they were going to do.
As of 6:30pm Larson had NOT left Topeka........so not sure what issues they were having
Monte
Re: For The Guys That Follow Drag Week [Re: Monte_Smith] #1668872
09/10/14 02:44 AM
09/10/14 02:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Always surprises me how many of these combo's have been screwed together days/weeks before drag week starts.... the hobby still has a heartbeat
Re: For The Guys That Follow Drag Week [Re: Street Monkies] #1668873
09/10/14 02:48 AM
09/10/14 02:48 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Not sure it qualifies as hear say, since I was standing there watching the car run, saw it strike the tires and also saw the time slip.........but ok.
Last years air was much better when the car ran that number. Weather so far has been soup and there was a SERIOUS headwind today at Topeka. Had the same tune in the Vette today that I had yesterday and it slowed from 193 and change to 189... Forecast calls for cooler toward end of week.
Monte
Re: For The Guys That Follow Drag Week [Re: Monte_Smith] #1668874
09/10/14 03:09 AM
09/10/14 03:09 AM
In a house near you
In a house near you
I should of checked over that last post alittle better before I sent It. I meant to say about hearing hear say from facebook. It wasn't directed towards you because I have no clue who or where you are. Obviously you are @ DW. Cool deal thanks for the Info and sorry on my part.
Re: For The Guys That Follow Drag Week [Re: Monte_Smith] #1668875
09/10/14 10:27 AM
09/10/14 10:27 AM
So Monte.... on a over all, how does it look this
year compared to last year... is there about the same
amount of cars that are out.... whats the average
DA so far for the tracks.. last year was HOT but your
saying the air isnt as good this year.. am I hearing
you correct..... have fun
Re: For The Guys That Follow Drag Week [Re: MR_P_BODY] #1668876
09/10/14 12:22 PM
09/10/14 12:22 PM
Montana
67DodgeCharger Offline
On vacation
On vacation
Montana
Does anyone have the live link for today? It has been really cool to see the street cars compared to what really is super stock
