What type of media blasting should you use??? #166869
12/13/08 05:37 PM
12/13/08 05:37 PM
London,Ontario,Canada
1962Savoy Offline OP
Can I media blast the bottom of my car without taking it all apart and repaint the bottom???
What is the best medium to use and the best paint?
it has a bit of surface rust showing up and I want to nip it in the bud now!
Re: What type of media blasting should you use??? [Re: 1962Savoy] #166870
12/13/08 05:42 PM
12/13/08 05:42 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No
Re: What type of media blasting should you use??? [Re: Challenger 1] #166871
12/13/08 05:44 PM
12/13/08 05:44 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
No
there was a thread here somewhere..that used foam..of some sorts.. and u didnt have to dissasemble it
Re: What type of media blasting should you use??? [Re: 340dart4spd ] #166872
12/13/08 09:32 PM
12/13/08 09:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I know of a couple cars were the owners got on their backs with one of those little hand held sand blasters and cleaned up the underside. One car was a 79 Trans Am and the other was a 72 Cutlass 442. I helped put dual exhaust on both cars. They painted the under side black. Those cars turned out great so yes it is possible to do.
Re: What type of media blasting should you use??? [Re: burdar] #166873
12/13/08 09:48 PM
12/13/08 09:48 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
What about walnut shells, I would think shells would clean it well enough to spray the bottom but not harm anything.
Re: What type of media blasting should you use??? [Re: Dave Watt] #166874
12/15/08 11:05 AM
12/15/08 11:05 AM
thanks I just want to clean up the bottom and stop the surface rust from continuing until a few years down the road I can do a rotisserie on her.
Re: What type of media blasting should you use??? [Re: 1962Savoy] #166875
12/15/08 11:18 AM
12/15/08 11:18 AM
Cincinnati, Ohio
Cincinnati, Ohio
Any media that will remove surface rust will be too abrasive and get in places that will harm your car when it is together. Then to recoat things when the car is together will be very tough and you will likely miss places and it will rust even faster.
