Problem is after I took the rally cluster out and reinstalled, I checked to see if everything was working before I screwed it back together. All the guages and tach are ok but the turn signals and dimmer are screwed up. They worked before.
Is there a ground to headlight and dimmer switch I'm missing? All plugs are connected. Turn signal works with the light switch off. Dimmer works on a test light to the bulb over the heater control but not to the pannel.
I replaced the flasher (which was very warm). Got to be something dumb, switches have power but why wouldn't the turn signals work when the headlight are turned on?
Also were can you get those little instrument bulbs. While testing the dimmer circut I noticed a couple out.
