Re: nascar motor
[Re: littleVAL]
#1668316
09/07/14 08:00 AM
09/07/14 08:00 AM
Posts: 6,150 Melbourne , Australia
LA360
R5 crank won't fit, the rear is different to a LA engine, as is the nose. The rods are generally swapped out as a precaution more than anything, they could probably last for quite a time in a lower rpm engine. Not sure about the big end width, but the pin diameters they run will require a custom piston. They are usually high 0.700"s to low 0.800"s in size.
Alan Jones
Re: nascar motor
[Re: scottb]
#1668323
09/07/14 10:44 PM
09/07/14 10:44 PM
Posts: 108 Socal
littleVAL
Socal
here is the link to ebay with a buy it now of $229 http://www.ebay.com/itm/NEW-JE-PISTON-RI...=item1e82c43d17 I had bought some rods because they where ridiculously cheap($40)knowing that they would probably end up as wall art but the same place has new bolts for only $207. My playing around is starting to seem like a plausible way of putting together a nice rotating assembly. I do agree they are very narrow only .89 so the ability of getting a crank in that size might be impossible unless I pay $3000+ As noted by others it is hard to find a piston that uses these rings so it is about $700 for the rings or turn a larger groove in them. I have a nice Clausing lathe that would easily do the job.
Re: nascar motor
[Re: littleVAL]
#1668325
09/07/14 11:20 PM
09/07/14 11:20 PM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
If the piston will center the rod, I wouldn't even be remotely concerned about side clearance. The bearing clearance is what will dictate how much oil you will have flying around the crankcase. If this stuff can be made to go in your block you will have way more in machining than parts. Sounds like a cool project that that won't bankrupt you if it does go boom. ![](/ubbthreads/images/graemlins/thumbs.gif) Kevin
Re: nascar motor
[Re: littleVAL]
#1668329
09/09/14 04:26 AM
09/09/14 04:26 AM
LA360
I am all for people doing things themselves, but I would make sure I could achieve the required surface finish and accuracy on my ring grooves before I did anything.
Alan Jones
Re: nascar motor
[Re: LA360]
#1668330
09/09/14 06:29 AM
09/09/14 06:29 AM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Cutting the ring grooves is a real pain, then I would rather buy another set of cheap used slightly bigger pistons with belonging rings (just for the rings) in correct thickness, and check /correct the end gap.... as a super budget job. For the valve notches the modern pistons with the strengthening ribs close to the wrist pin allows for some cutting suited to a wedge engine without getting too thin. This is the way I will build my R3/W8 engine at 4.180" bore. Do not forget that these lightweight parts demand crankshaft balancing, and if you want to benefit the small big-end it means offset grinding the crank, what I mean to say there is some work to be done that adds to the cost. Also, be aware of the LA deck height means you need longer rods than what is common, so you have to plan for this. If your base is a 9" R3 then it is simpler. All these parts are based on the 9" sbc dimension. To make them work in a 360 you need to have a 4" stroker as a base, and then add the offset grinding. I am fortunate to own both a crankshaft grinder and a balancer, so for me it is just hobbywork and fun. You can also E-buy a dry sump system cheap, if you use a 3-stage pump they go for appx 250-300$, and a tank you can get for 50-150$, and used hoses also cheap. Budget jobs are always fun, and you create your own engine, if something goes wrong it does not matter and you can repair it the same way. The most important is to plan the whole project, and calculate it both with new conventional parts and as an alternative with the used cheap racingparts. Then you will see what you can save, and the risks involved and the remaining building cost. Good luck! ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: nascar motor
[Re: Oyvind Mopar]
#1668331
09/09/14 11:09 AM
09/09/14 11:09 AM
Posts: 108 Socal
littleVAL
Socal
I really thought a dry sump would be much more. Maybe this idea is not dead. I had planned on a 4.25 stroke with 6.2 rods. I had figured buying some used $10 pistons and see if I could make the necessary machining without any problems before buying other parts. For a short time I worked at a place that made turbo bearings. They told us that there was only one place in the US and one in Japan that makes them for everyone. I would turn out about 600 in a shift and the night guy would do the same
Re: nascar motor
[Re: LSP]
#1668334
09/11/14 11:47 AM
09/11/14 11:47 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Like someone already mentioned, the snout would need to be machined on the R5 crank to go into a R3 block, but all the R5 cranks are short stroke so I'm not sure what would be gained.
Neither end of the R5 (1 or 2 piece rear) crank will fit in a LA block. Also the mains are (2.250) SBF in a R5.. LA are 2.500 (340) or 2.810 (360)
