RF tire wearing on outer edge only?
#1668252
09/06/14 11:09 PM
09/06/14 11:09 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Noticed the odd wear pattern on the RF of my '06 2500 4x4 CTD. Obviously a ball joint or wheel bearing. Any known problem with this? Probably jack it up tomorrow to check it out. Any preference on parts? Thanks,
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: RF tire wearing on outer edge only?
[Re: Kern Dog]
#1668254
09/07/14 03:13 AM
09/07/14 03:13 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
They use a sealed unit bearing on the front. Its sold as a complete unit, they can be a pain to replace if they have seized.
They are a known wear item, especially if you run a larger than stock tire.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1668256
09/07/14 02:39 PM
09/07/14 02:39 PM
I_bleed_MOPAR
Buford, GA
Haven't had a chance to check it yet (being retired is great ). Quote:
Arent those solid axle front ends? If so there must be some sort of bent component.
Still has BJs and a unit wheel bearing.
Stock tires (except for a brief time when I had some 285 Muds on it). From what I've been able to find, it can be either BJs or the wheel bearing assembly. Neat video on youtube about how to push the hub out.
https://www.youtube.com/watch?v=gpH0SlYS6YM
Tim
