Re: 8 bolt dodge rims?
[Re: redraptor]
#1668149
09/07/14 11:56 AM
09/07/14 11:56 AM
Posts: 129 London Ontario Canada Eh
Dono
You need to give a little more info. As far as off the shelf, anything wider than 12", no. As far as tires, Mickey Thompson makes some pretty wide ones but none are E-rated. So what is he planning to do with said truck?
Ok the boys truck is more of a trar.... truck/car that he drives to school and around. There is large stacks in the truck box so the box is just used for little light loads.
She is a first gen cummins diesel stick. When I have some time I will pull the rear wheels off and measure up what room there is and what offset is needed.
Tires I know are quite easy and M/T will be the tire of choice. Just wondering if there has been anyone on here that may have looked at doing this to an 8 bolt dodge diesel. I would expect having the two rims it would need to be 14"s plus anyways.
Cheers Don.
[Re: 76dodgeboy]
#1668153
09/08/14 09:10 PM
09/08/14 09:10 PM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
Its a Dually he can run a 16" wide rimbgiven the correct bs
The rims in the pic are 19" wide and that 9 1/4 is dimensionally the same backing plate to backing plate as my dana 80. The outside dimension of the tire is the same too on my dually. This sounds like an incredibly expensive experiment to a non problem.
[Re: Dono]
#1668154
09/09/14 09:18 AM
09/09/14 09:18 AM
Guitar Jones
That is a 2nd gen truck.
[Re: 76dodgeboy]
#1668158
09/10/14 09:14 PM
09/10/14 09:14 PM
redraptor
Greenville, PA
Lol. Here we go again. When Talking to DIESEL Guys First gen is refered tobas the Engine Not truck. When talking Gas trucks First gen is referee to as the Ram. I think the term First or sececond gen is Dumb and reminds me of craperos and imports
Wow. I had no idea. What's the difference in the '93 diesel and '94 diesel engines?
[Re: redraptor]
#1668159
09/11/14 04:22 AM
09/11/14 04:22 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
A 93 will have a VE injection pump and a 94 will have a P7100 injection pump, then a 98.5 will have a VP44 injection pump AND 24 valves. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
[Re: 76dodgeboy]
#1668160
09/11/14 09:10 AM
09/11/14 09:10 AM
Guitar Jones
You can think it's dumb if you want but the terms are there to differentiate the various incarnations, and there are distinct differences. Yes, even the wheels. Take a look over at dieseltruckresource.com and you'll see how they are split up.
[Re: 76dodgeboy]
#1668162
09/11/14 08:55 PM
09/11/14 08:55 PM
redraptor
Greenville, PA
Those that go buy the 81-93 Ram being being first gen are technically incorrect. Sorry for veering off topic
You tell'em Harry! They are still D series pickups. Wonder what confusion will happen when Ram isn't a stand alone brand?
