Possible new racing category. #1668027
09/06/14 11:06 AM
09/06/14 11:06 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
With all the talk of non Mopar racing engines and Mopar not having any real parts for the big leagues, I was wondering if a new class would work for us.
Take any car you want do want you want to it from the suspension to the transmission. Add any power adder you want to use for different categories. But you must use a OEM block and heads.
Fill the engine with what you want parts wise.
Does this category already exist?
Matt.
Re: Possible new racing category. [Re: MattW] #1668028
09/06/14 11:40 AM
09/06/14 11:40 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
..... so "superstock", with a power adder!
Re: Possible new racing category. [Re: J_BODY] #1668029
09/06/14 12:03 PM
09/06/14 12:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Or Bracket Racing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Possible new racing category. [Re: pittsburghracer] #1668030
09/06/14 12:20 PM
09/06/14 12:20 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Lol same as what Monty races in, but OEM block and heads.
Soon that style of racing will be billet block and heads.
It will turn into a Nascar thing. One off everything.
It would be nice to see something that resembles a factory offering.
Is it viable? Or am I out in left field?
Matt
Re: Possible new racing category. [Re: MattW] #1668031
09/06/14 12:52 PM
09/06/14 12:52 PM
Guitar Jones Offline
I would think that having to use factory blocks and heads it would turn into another high dollar effort given the extreme modifications that would need to be done to make that stuff work.
Just look at the 10.5 stuff and how it progressed. It was meant to be a limiting factor but instead it turned into a lot of high tech, expensive stuff in order to get traction.
Re: Possible new racing category. [Re: pittsburghracer] #1668032
09/06/14 12:58 PM
09/06/14 12:58 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Or Bracket Racing.
Only in America,only in Bracket Racing can you build not only your choice of car but build it any way you choose and have a class to race in every weekend!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Possible new racing category. [Re: MRMOPAR622] #1668033
09/06/14 01:02 PM
09/06/14 01:02 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
First nobody will run it, then put a decent payout and the cars will come. Then the little guy the class was made for won't have enough money to compete. Unfortunately rules = big money.
Its not like the old days where you needed to make your own stuff, now all you need is money and the internet to find the place to spend it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Possible new racing category. [Re: bigtimeauto] #1668034
09/06/14 01:31 PM
09/06/14 01:31 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
That kind of a class sounds appealing to me. Could you not put a bunch of limits on modifications that would keep the $ down? Have a spec suspension everyone must use (4 link), stock front suspension, limit blower/turbo size, and a certain lbs/cu in. Port the heads as much as u want. Would that help keep $'s down? Or where does the $$$ dollar output come from
Re: Possible new racing category. [Re: WO23Coronet] #1668035
09/06/14 02:54 PM
09/06/14 02:54 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
would end up stupid expensive in a hurry.
as for engines used,it would probably be a class for Hemi´s rectangularport bigblock chevys (might even derail into a L88/ZL1 class) a bunch of cobrajet 429/460 fords and 4barrel clevelands also some LSstuff. and then the moparcrowd will start bitching about the cost of HEMI´s and how the bigblock Wedge and the smallblock mopar is at a dissadvantage and everything is to expensive
