how do you lube your tube? #1667697
09/04/14 11:01 PM
09/04/14 11:01 PM
SD
Z
zrxkawboy Offline OP
Z
SD
Your fuel filler tube, of course. I'm installing a new seal where the tube enters the tank. What is the best lube to use on the seal? Thanks!
It's Swifty! Swifty, you toad sucker!
Re: how do you lube your tube? [Re: zrxkawboy] #1667698
09/04/14 11:02 PM
09/04/14 11:02 PM
Kirkland, Washington
Pacnorthcuda Offline
Vaseline.
Re: how do you lube your tube? [Re: zrxkawboy] #1667699
09/04/14 11:47 PM
09/04/14 11:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Soap and water, like in the shower LOL, it evaporates and leaves no mess behind, LMAO
Re: how do you lube your tube? [Re: TJP] #1667700
09/05/14 12:01 AM
09/05/14 12:01 AM
IN
ahy Offline
ahy  Offline
IN
Silicone grease is considered best (ACE plumbers silicone, AP store ect) but just about any grease should work. Soap and water would help but no corrosion protection to the "clean" part of the fill tube after installation.
