hand cranking engine.. how much torque before snapping? #166769
12/13/08 11:00 AM
12/13/08 11:00 AM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
the crank bolt???? crank bolt has a 3/4 head on it and all I have done is tighten the bolt about a 1/4 turn and I am afraid of snapping it. This is in my boat that has sat for over 4 months and the engine is froze-up.........
I did spray PB blaster in all the cylinders and then topped them off with marvel mystery oil and let em soak for 24 hours.
Of course I don't want to snap the crank bolt and I am wondering if there is an alernate way to spin the engine over?? Maybe attach a harmonic balancer puller the crank pulley and use a giant breaker bar? I just replaced the starter and it will fail if I try to start an engine that won't spin...... TIA TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: hand cranking engine.. how much torque before snapping? [Re: tpabayflyer] #166770
12/13/08 11:05 AM
12/13/08 11:05 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Can you get at the flywheel with a prybar?? I think once you get it broken free a little, you can go back to the crank bolt to give it a few more rotations.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: hand cranking engine.. how much torque before snapping? [Re: CJK440] #166771
12/13/08 11:39 AM
12/13/08 11:39 AM
Tampa, FL
Tampa, FL
No clearance at all towards the back of the engine.... I am going to go out and remove the crank pulley. I am going to go to the junkyard and try to match one up. My idea is to weld some steel tubing to the outside of the pulley and then stick my breaker bar in the tubing and let it rip. That should allow alot more torque than the turning the center bolt..... I need to think outside the box like "MacGuyver"!! TBF
Re: hand cranking engine.. how much torque before snapping? [Re: tpabayflyer] #166772
12/13/08 11:51 AM
12/13/08 11:51 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
maybe a nice long chunk of angle iron. drill two holes that match your pulley and crank away.
might want to let that solvent soak longer. I assume you do not want to take the heads off, If you did you could tap on the cylinders a little. do you have the spark plugs out?
I have mechanical Aptitude.
I can screw up anything.
Re: hand cranking engine.. how much torque before snapping? [Re: bboogieart] #166773
12/13/08 01:25 PM
12/13/08 01:25 PM
Tampa, FL
Tampa, FL
Oh yeah... plugs are out... removing the engine from the boat is a big deal and I want to avoid that at all costs....
I posted this question on another site and a marine mechanis said to use a large strap wrench around the pulley.... I did not even know they made them any bigger than the oil filter ones but sears has them..... TBF
Re: hand cranking engine.. how much torque before snapping? [Re: tpabayflyer] #166774
12/13/08 01:52 PM
12/13/08 01:52 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Pull the balancer and use a crank socket.
NMCA NSS 67 Coronet
Re: hand cranking engine.. how much torque before snapping? [Re: Barry70GTX] #166775
12/13/08 02:53 PM
12/13/08 02:53 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
For watt its worth I had a locked up /6 that I tried to break free w th crank bolt (3/4)
used a 6 ft pipe on breaker bar and ended up rocking the whole car on the suspension before I gave up. They ran it lo on oil then topped it off before selling. $100 Junk yard motor fixed that and gave 20+ mpg
I dont think you will break that bolt but attaching to the balancer or a crank socket is a better idea
Re: hand cranking engine.. how much torque before snapping? [Re: racincuda] #166776
12/13/08 02:58 PM
12/13/08 02:58 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I am confused (not that tuff fer me)
what is a crank socket?
Re: hand cranking engine.. how much torque before snapping? [Re: bboogieart] #166777
12/13/08 03:11 PM
12/13/08 03:11 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: hand cranking engine.. how much torque before snapping? [Re: bboogieart] #166778
12/13/08 03:13 PM
12/13/08 03:13 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Fits over the snout of the crank after you take off the pulley & balancer; it has a keyway cut that engages your crank. Here's mine:
Re: hand cranking engine.. how much torque before snapping? [Re: vdriver] #166779
12/13/08 03:14 PM
12/13/08 03:14 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Like this:
Re: hand cranking engine.. how much torque before snapping? [Re: vdriver] #166780
12/13/08 03:16 PM
12/13/08 03:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sweet tool, that is kinda what I thought.
I have been lucky and not needed one yet but good to know. Will one tool fit all mopars? How much?
Re: hand cranking engine.. how much torque before snapping? [Re: vdriver] #166781
12/13/08 03:19 PM
12/13/08 03:19 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Then you can do this:
Re: hand cranking engine.. how much torque before snapping? [Re: bboogieart] #166782
12/13/08 03:20 PM
12/13/08 03:20 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Mine fits both small & big block.
Re: hand cranking engine.. how much torque before snapping? [Re: vdriver] #166783
12/13/08 06:26 PM
12/13/08 06:26 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
If you try to use the pulley, you'll bend the hell out of it.
Re: hand cranking engine.. how much torque before snapping? [Re: Barry70GTX] #166784
12/13/08 06:51 PM
12/13/08 06:51 PM
Tampa, FL
Tampa, FL
You are vewy kweva gwasshoppa.... Thanks for idea Barry, I did not even think of that as well. This is a 454 chev so I am sure they make them. I got a sears strap wrench and hooked it up with my 6ft long pipe "torque multiplier" and it snapped the cheezy rubber strap "el-pronto'..... Being the MacGuyver that I am. I grapped an extra serpentine belt and it just happened to fit in the tool. I gave that a try and it fit in the pulley nice and snug but when I started putting some serious force on the end of the pipe it snapped the aluminum handle......... Maybe a real big strap wrench would work but I must have been putting 500 ft/lbs of torque at least on it before it snapped. I puled a riser and found water intrusion so i have some rust issues that must have caused the seizure. The plugs did not look that bad with no rust on them?
Thanks for the ideas guys, I was trying to get this thing fixed before I go in for shoulder surgery next week so this project will have to wait...... TBF
Re: hand cranking engine.. how much torque before snapping? [Re: tpabayflyer] #166785
12/13/08 07:48 PM
12/13/08 07:48 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
once you pull the engine, your machinist will love you..
I am truckless..
Re: hand cranking engine.. how much torque before snapping? [Re: tpabayflyer] #166786
12/13/08 11:07 PM
12/13/08 11:07 PM
there's really no reason not to pull the engine. if it's locked up that tight it needs to be rebuilt or junked.
Re: hand cranking engine.. how much torque before snapping? [Re: tpabayflyer] #166787
12/14/08 01:11 AM
12/14/08 01:11 AM
but I must have been putting 500 ft/lbs of torque at least. I was trying to get this thing fixed before I go in for shoulder surgery next week so this project will have to wait...... TBF
When you get your shoulder rehab'd you should be able to put more than 500 ft lbs into it, it'll break loose.
Re: hand cranking engine.. how much torque before snapping? #166788
12/14/08 08:37 AM
12/14/08 08:37 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
If it's that stuck, the cylinder walls are probably a mess. Just take it out and see what you have.
MB
