torsion bar sliding out of mount #166725
12/13/08 07:48 AM
12/13/08 07:48 AM
Page AZ
Diplomatt Offline OP
Rodney Dangerfield Jr.
Page AZ
on my 1982 cordoba, the drivers side torsion bar is sliding out of the bushing that is by the front shock. It happened when I was driving for some reason, and I almost crashed on my way back home from work. Is it the bushing and mount that needs to be replaced? Does anyone in the eastern RI/Eastern MA area know of any shop that knows older cars? Im stuck at school with no tools or anything to work on a car...
Re: torsion bar sliding out of mount [Re: Diplomatt] #166726
12/13/08 09:02 AM
12/13/08 09:02 AM
IN
polaraholic Offline
polaraholic  Offline
IN
There should be a c-clip on the other end that keeps it from sliding back. A parts store should have them.
Re: torsion bar sliding out of mount [Re: polaraholic] #166727
12/13/08 09:16 AM
12/13/08 09:16 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Remember the Cordoba uses a transverse mounted torsion bar. I have a service manual for 1982 and will try to copy a diagram of the front suspension. I would make sure that the end of the bar isn't broken. I wouldn't think that there should be enough movement for the bar to slip out if the end of it wasn't broken off.
Re: torsion bar sliding out of mount [Re: burdar] #166728
12/13/08 09:26 AM
12/13/08 09:26 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here is the diagram. There are a couple more diagrams as well. If you need to see them let me know.
Re: torsion bar sliding out of mount [Re: burdar] #166729
12/13/08 09:36 AM
12/13/08 09:36 AM
IN
polaraholic Offline
polaraholic  Offline
IN
I guess that is a little different than my old stuff. Great info!
Re: torsion bar sliding out of mount [Re: polaraholic] #166730
12/13/08 10:23 AM
12/13/08 10:23 AM
Lebanon CT.
moparjoe4406 Offline
Joe the plumber
Joe the plumber
Lebanon CT.
Thats good stuff,Matt I printed that info and I'll bring it tonite,hopefully its just a clip or something,if not I don't know who would have a torsion bar like that.
Re: torsion bar sliding out of mount [Re: burdar] #166731
12/13/08 12:03 PM
12/13/08 12:03 PM
Page AZ
Page AZ
Thanks for that diagram! I hope the bar itself is fine, I don't know where I would find one of those
Re: torsion bar sliding out of mount [Re: Diplomatt] #166732
12/13/08 01:04 PM
12/13/08 01:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Bad news, that T-bar also serves as the strut rod. If it's sliding out then something is broken.
Might just be the bushing.
Don't be the exception.
Re: torsion bar sliding out of mount [Re: Supercuda] #166733
12/13/08 09:28 PM
12/13/08 09:28 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Let us know what you find out. Good luck!
Re: torsion bar sliding out of mount [Re: burdar] #166734
12/13/08 09:47 PM
12/13/08 09:47 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I would be a little skeptical as to why it is sliding out so easily? It should have a lot of tension on it when adjusted properly. Make sure you check all your suspension parts for damage.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: torsion bar sliding out of mount [Re: G-Money1320] #166735
12/14/08 01:54 AM
12/14/08 01:54 AM
Lebanon CT.
Joe the plumber
Joe the plumber
Lebanon CT.
Anyone know a good frontend place in R.I. or Eastern Mass?
Re: torsion bar sliding out of mount [Re: moparjoe4406] #166736
12/15/08 09:01 AM
12/15/08 09:01 AM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
The T-bar is pinned to the bushing, check www.car-parts.com there were a few on there last I checked.
