using hyd oil in trans to lower flash rpms #1667016
09/02/14 11:50 PM
09/02/14 11:50 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
has anyone used utf (universal tractor fluid)and if so which brand
what is realistic?
i am wanting to lower my flash rpms to see if my car likes a tighter
converter before taking it out for the restall.
i added timing to the car and it seemed to bump the flash up 200 rpms
and i was wondering what it would be like to get it down to 5300 or so.
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667017
09/03/14 12:05 AM
09/03/14 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
what is realistic?
With the timing your making more torque so the stall
went up... I cant say about the trans oil. I try
to go up normally
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667018
09/03/14 01:23 AM
09/03/14 01:23 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run john Deere hy-guard low viscosity so it's only 10 weight. Keeps temps down though.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667019
09/03/14 02:30 AM
09/03/14 02:30 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
My friends use it in turbo DSM's if the trans is still cold it takes a long time to get up on the converter and stage
Re: using hyd oil in trans to lower flash rpms [Re: SpareParts] #1667020
09/03/14 06:28 PM
09/03/14 06:28 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
67dartgt
how much do you put in and how much did it lower your flash.
i am running napa dex3 rite now.
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667021
09/03/14 07:21 PM
09/03/14 07:21 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Lenny @ Ultimate told me the low viscosity Hy-Guard would raise flash stall some.
Re: using hyd oil in trans to lower flash rpms [Re: LSP] #1667022
09/04/14 01:02 AM
09/04/14 01:02 AM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
would you run it at 100% or the easy way and do a fluid and filter change with it and see what happens with the stall?
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667023
09/04/14 04:25 AM
09/04/14 04:25 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I've yet to use the stuff, going to start with the std. viscosity in my new TH400/Griner brake/7" combo right from the start and see how it goes. Hearing that the Hy-Guard handles heat better than type F, but I'm not recommending it at this point, just passing on what my converter guy had to say.
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667024
09/05/14 02:14 AM
09/05/14 02:14 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
67dartgt
I run low vis and it didn't really change my stall at all. I run 100% hy-guard even drained conv when I switched. It raised mine maybe 100-200 rpm, you can buy low vis hy guard and it will lower your stall.
Re: using hyd oil in trans to lower flash rpms [Re: 1967dartgt] #1667025
09/05/14 09:36 AM
09/05/14 09:36 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Go to your local tractor supply store and get some ISO 68 hyd fluid it should drop your stall 200 to 300 rpm
Re: using hyd oil in trans to lower flash rpms [Re: challenger1320] #1667026
09/06/14 02:30 PM
09/06/14 02:30 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
ok so iso 68 is the number to get? the iso 32 is too close to the atf to make a difference? or iso 32 goes looser...
i will give it a try after another time at the track for more data then try it.
Re: using hyd oil in trans to lower flash rpms [Re: dmking] #1667027
09/08/14 10:31 AM
09/08/14 10:31 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
The 303 hydraulic fluid in my car will tighten the convertor 300 RPM's.. And thats coming off the racepack replay so it's pretty accurate .
Re: using hyd oil in trans to lower flash rpms [Re: sc301v] #1667028
09/08/14 11:12 AM
09/08/14 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So is it thicker than say type F.... if we were to say
a thicker viscosity will lower the stall would that
be correct?
Re: using hyd oil in trans to lower flash rpms [Re: MR_P_BODY] #1667029
09/08/14 12:27 PM
09/08/14 12:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
be correct?
Yes
