3/8 Fuel Pump top Carb Lines
#1666953
09/02/14 05:48 PM
09/02/14 05:48 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
Does anyone make 3/8 fuel pump to carb lines for a small block? All I can find are 5/16.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 3/8 Fuel Pump top Carb Lines
[Re: Erik]
#1666955
09/02/14 07:15 PM
09/02/14 07:15 PM
Challenger 1
Cincinnati, Ohio
That's becuase you don't need 3/8", not even on the nastest big block. 5/16" is plenty and 3/8" is a waste and just sucks up more heat for between the pump and carb.
[Re: Challenger 1]
#1666956
09/02/14 11:56 PM
09/02/14 11:56 PM
Erik
Stroudsburg, PA
My whole system is 3/8 with the exception of the pump to carb lines.
[Re: Erik]
#1666957
09/03/14 03:21 AM
09/03/14 03:21 AM
Challenger 1
Cincinnati, Ohio
That's right, the inlet plumbing should always be one size larger than the discharge plumbing on any fuel system and on just about any pump, not just fuel pumps.
