Re: How bad is engine blowby
[Re: 68Bullit]
#166665
12/12/08 08:42 PM
12/12/08 08:42 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
You'll need a leak down tester and an air compresser. It's fairly simple. Set engine to TDC (hot is best), set air to read 100 psi, any drop in the reading of the second guage is the % of leakage. i.e. 98 psi would be 2% leakage.
For real world readings, do all cylinders at TDC and BDC
[Re: 68Bullit]
#166667
12/12/08 10:38 PM
12/12/08 10:38 PM
RapidRobert
When you hit each cyl with air,in addition to the percentage, to find out WHERE the leakage is, listen at the tailpipe-ex valve, carb-intake valve, radiator-bad head gasket/cracked head/block, in your case- breather cap-rings/cyl walls.
[Re: RapidRobert]
#166668
12/13/08 08:35 AM
12/13/08 08:35 AM
WILD BILL
BROOK PARK, OH
For my race motors I shoot for less than 10%. I light up a cigar if their all 5% or less
You'll never see 0% across the board. At least I've never heard of it.
On a daily driver I would be ok W/ #'s in the 10 to 17% range. Anything greater and I'ld be looking for the cuase.
