Re: Draining a 66 Belvedere gas tank?
[Re: RemCharger]
#166652
12/12/08 08:48 PM
12/12/08 08:48 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Disconnect the fuel line and run it into a can. Take a blow gun and using compressed air, pressurize the tank through the filler neck. You can even run the siphon hose into the filler neck, but its easier to drain further down the fuel line
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: b5rr]
#166654
12/13/08 11:47 AM
12/13/08 11:47 AM
RapidRobert
you could put a T in the pump to carb line & run it out to a barrell as the eng idles.
[Re: RapidRobert]
#166655
12/13/08 02:54 PM
12/13/08 02:54 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If its the same as my '67, which it should be, it takes less than a half hour to remove the tank completely. I pulled mine & had a new one in and completely buttoned up in a couple hours. There should be only one strap, dissconnect the fuel and breather lines (which are pretty much standard hose couplings), and remove the fuel line from the sending unit. bam, it falls out.
