Yes it is pretty easy.....with the exception of the filler tube. All the above to remove. And BTW this is what should be done to clean out....pull it. When reinstalling the filler tube is a PITA. It's blind as you install. Get a new grommet for good sealing. Take your time....but it should be done this way. JMHO
