Page 3 of 3 1 2 3
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666542
09/29/14 09:51 AM
09/29/14 09:51 AM
Georgia
Steve Bryant Offline
Georgia
Yeah, I noticed that with my E-Body as well. With mine, the fluid level does not change much in the overflow...perhaps an inch or so after the initial equalization.
However, then the car is pretty hot and I stop somewhere it still overflows just a little onto the ground. Now that it is cooling off, I expect that behavior to stop.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1666543
09/29/14 12:09 PM
09/29/14 12:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I question if your using the correct style tank, per my link above. That style tank must be mounted above the radiator and is designed to be used as fill for a radiator. That style won't work correctly down low with our radiators that are designed to be filled through the radiator cap.
Re: Radiator Coolant Recovery Tank [Re: Scott Carl] #1666544
09/29/14 12:44 PM
09/29/14 12:44 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I am looking at adding a coolant recovery tank on my 70 Challenger. I have been looking at what is available through Dorman and I found their universal unit (603-001) and I also came across #603-121 (1992-2002 Saturn) pictured. So far I like it better because it looks smaller and I could mount it in front of the radiator support which might hide it a litter better.
http://www.dormanproducts.com/p-44832-603-121.aspx
I am looking for other ideas on what style/part number of unit and where did you mount yours on the older cars.
I used a 73-74 repo and bracket for my 74, it'll fit all other E body's also.
Sorry for the late response, but as I have a 74, this idea was what I was thinking when I read the OP. Its stock albeit not correct. However if you're adding it, year correctness isn't an apparent concern
Scott
I have that same bottle on my 73 wagon. However, I have it mounted on the passenger side.
Re: Radiator Coolant Recovery Tank [Re: dart4forte] #1666545
09/30/14 02:41 AM
09/30/14 02:41 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I have a 74 and am not worried about originality. I just got a rectangular generic bottle and mounted it up inside the driver side fenderwell. Ran the hose stockish along the radiator top, then down through the radiator support. Nobody has ever noticed that it has an overflow bottle.
Re: Radiator Coolant Recovery Tank [Re: Challenger 1] #1666546
09/30/14 10:55 AM
09/30/14 10:55 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
""I question if your using the correct style tank, per my link above. That style tank must be mounted above the radiator and is designed to be used as fill for a radiator. That style won't work correctly down low with our radiators that are designed to be filled through the radiator cap.""
I used the Dorman 603-121 which is called a "Pressurized Coolant Reservoir". The tank is mounted lower than the top of the radiator and the fluid moves back and forth with no problems.
After my last drive, the coolant reservoir once again went dry. This is the fourth time that I have added coolant to the reservoir and the radiator sucked it in. I must have had a decent size air bubble in the system.
Thanks for the replies. I am going to keep adding coolant to the reservoir until the level stays within the height of the reservoir after a full driving and cool down cycle.
Re: Radiator Coolant Recovery Tank [Re: second 70] #1811785
04/25/15 06:56 PM
04/25/15 06:56 PM
WA
tman Offline
tman  Offline
WA
Originally Posted By second 70
I used the wiper tank on my hemi cuda and it works great. No one even knows it's being used for the overflow. The trick is you put the overflow hose on the bottom but you MUST drill an air hole in the the back of the wiper tank otherwise it will air lock. I drilled a 1/4 hole in the rear corner where it's under the hood pin mount so you can't tell it's there. No problems in 5 years of use even in 100 degree weather. You only need about 2" of coolant in the tank when cold and mine's about 3/4 full hot. Has never blown top off or overflowed. Good luck. Mike
I too would like to use your method of using the wiper tank for my 70 Cuda. Can you give some detail as to how you did that?
Did you use the Manual wiper tank with nipple at the bottom, or did you have to modify it? I don't know if the overflow hose will fit that nipple. I currently have an electric wiper tank.
My radiator overflow hose points out to driver side, how did you route your hose to the wiper tank?
I totally understand drilling the tank so vacuum will allow coolant to flow back to radiator.
Hope you see this and THANKS.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1811847
04/25/15 09:00 PM
04/25/15 09:00 PM
AndyF Online content
AndyF  Online Content
I picked up a recovery bottle from a 2000 Toyota 4Runner. It is a nice square shape that will fit next to the radiator on my '65 Coronet.
Adding a coolant recovery setup like this is a good deal on the older cars since it allows you to run the radiator full of coolant. The extra coolant adds some thermal capacity to the system.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1812085
04/26/15 01:31 AM
04/26/15 01:31 AM
WA
tman Offline
tman  Offline
WA
Trying to keep my car stock looking by using the wiper tank. Just need specific info how its done. Thanks for your solution.
Re: Radiator Coolant Recovery Tank [Re: YO7_A66] #1837760
05/31/15 05:08 AM
05/31/15 05:08 AM
WA
tman Offline
tman  Offline
WA
Took a chance and purchased s Repro manual wiper tank. The 5/16 overflow hose will attach to the nipple at the bottom. Just put on a 3/8 spring clamp to secure the hose. My overflow hose exits out towards the driver side. So I purchased a bulk length of 5/16 overflow hose. The hose exits as it normally does, but I had the hose routed below the radiator towards the wiper tank. The overflow hose will lay on the radiator support. Very simple.
I then drilled a hole near the top of the tank that is hidden from view. The hole is just large enough so I could press in overflow hose so if it gets overfilled, it will vent to the ground.
Also purchased a radiator cap that is vented. The overflow did go into the tank and when the engine cooled, the coolant went back in to the radiator.
Page 3 of 3 1 2 3
