A Body 4 speed Shifter Unit Question
#1666485
09/02/14 10:57 AM
09/02/14 10:57 AM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
This past weekend I installed the shifter and shift rods in my cuda. The shifter is a rebuilt/restored unit from Brewers and the shift rods were from Mancini. The reverse rod was about 3" too long, so I assume Mancini sent me a b or e body rod. When I went to test everything to make sure it worked, the shifter would only move one rod. The unit had ZERO lateral movement to engage the other rods. When I installed it, I took it out of the box, removed the plastic retainer and installed it. Anyone have a guess as to why I would have no lateral movement to engage the other rods?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A Body 4 speed Shifter Unit Question
[Re: Dan Brewer]
#1666488
09/02/14 01:34 PM
09/02/14 01:34 PM
Erik
Stroudsburg, PA
John,
I was able to shift everything on the trans manually, and used the same plate that was on the car when I pulled it apart. I think I'll disassemble everything and start over again.
Yes, the rods have a gold hue. I didn't like what I saw and how they fit, but they were better than what I had. I'll try to return them and get a set from Brewers.
