Auto trans guys, what am I looking at here??....... #1666315
09/01/14 07:15 PM
09/01/14 07:15 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
.......... besides lots of money
727 behind the 440 in my Barracuda. Has a number of performance upgrades. Pro Trans RMVB, 4 pinion planet, all rollerized, aluminum drum, lightened sun shell, etc., etc..
Noticed this a couple years ago and have not started the car until recently because fluid looked horrible. I did check it often when running it but I think something happened with the last couple street trips.
Any guesses?
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666316
09/01/14 07:20 PM
09/01/14 07:20 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I wonder if the filter got clogged at a later point but it looks like a lot of clutch and burned ATF.
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666317
09/01/14 07:20 PM
09/01/14 07:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
time to take it apart. check the endplay before diassembly.
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666318
09/01/14 07:20 PM
09/01/14 07:20 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
if it wont stick to a magnet, i say clutch or band material.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666319
09/01/14 07:22 PM
09/01/14 07:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Clutch or band or both material
Re: Auto trans guys, what am I looking at here??....... [Re: MR_P_BODY] #1666320
09/01/14 07:45 PM
09/01/14 07:45 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Well I suppose it has to come out and get it gone through and cleaned up. Should send the converter out to get cut and cleaned as well.
It was fun while it lasted
Re: Auto trans guys, what am I looking at here??....... [Re: MR_P_BODY] #1666321
09/01/14 07:47 PM
09/01/14 07:47 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Greg I've seen that before when the fluid pressure dropped and wouldn't hold the clutches. We have to disassemble carefully for proper diagnosis to prevent this from happening again.
I'm kinda busy til after Norwalk but I can swing by after that.
Gus
64 Plymouth Savoy
Dana 60
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666322
09/01/14 07:57 PM
09/01/14 07:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check ur stator to see if it free wheels. Other than that, ur trans is junk.
Re: Auto trans guys, what am I looking at here??....... [Re: rickraw] #1666323
09/01/14 08:12 PM
09/01/14 08:12 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Was it working ok? Check the 2nd gear band adjustment. It looks like aluminum off the drum. How often you change fluid?
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Auto trans guys, what am I looking at here??....... [Re: Dan Brewer] #1666324
09/01/14 08:18 PM
09/01/14 08:18 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Aluminum drum on street?? Not a good combo.imo
JAKES AUTOMOTIVE
Re: Auto trans guys, what am I looking at here??....... [Re: Dan Brewer] #1666325
09/01/14 08:36 PM
09/01/14 08:36 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
I didn't have very many 1/4 mile passes on it (50-75?) and for street miles, not many, I'd assume under 100?
I know the deal with aluminum drum on the street and that's why I regularly checked the fluid. Just one day it was dark so it got parked.
Was working OK the last time out with it on the street. Was also planning a fluid change to keep on top of it.
It just suddenly darkened the fluid, loss of pressure like Gus suggested?
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666326
09/01/14 08:40 PM
09/01/14 08:40 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
Did it have the Teflon rings on front pump? If it had steel ones, that would be the problem! Ask me how I know!!!
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666327
09/01/14 09:03 PM
09/01/14 09:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How was it shifting? It looks like normal Aluminum drum mud. I'd clean it out and put a filter in it, see how it goes. If the clutches are burned up your only out the price of fluid and filter. You're not going to kill it any worse. It may be fine. As Jake said aluminum drum on the street is going to create a lot of "aluminum mud".
Doug
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666328
09/01/14 09:32 PM
09/01/14 09:32 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
No magnet in the pan???
Re: Auto trans guys, what am I looking at here??....... [Re: RSNOMO] #1666329
09/01/14 09:47 PM
09/01/14 09:47 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I feel your pain... ...mine is out for the same reason. Hope it is finished by Norwalk.
Re: Auto trans guys, what am I looking at here??....... [Re: dvw] #1666330
09/02/14 11:44 AM
09/02/14 11:44 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Doug
I agree with Doug. Clean the pan, adjust the band and new fluid. With the aluminum drum you need to change the fluid / filter more often. You also need to use the stock type filter not the brass one.
Re: Auto trans guys, what am I looking at here??....... [Re: Dan Brewer] #1666331
09/02/14 02:48 PM
09/02/14 02:48 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Doug
I do not agree with this because you do not know how what is going on in the trans forsure in my opinion.With that much in the pan I would be concerned.I agree with the stock filter[fiber].Again JMO.
Re: Auto trans guys, what am I looking at here??....... [Re: Clanton] #1666332
09/02/14 02:59 PM
09/02/14 02:59 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Well I'm going to clean the pan, lines and cooler.
It had the brass screen filter on it and I'm going to install the fiber filter and some new fluid.
As long as it moves that's all I need at the moment. No time for racing in the near future.
Thanks for all the input
Re: Auto trans guys, what am I looking at here??....... [Re: roadhazard] #1666333
09/02/14 04:08 PM
09/02/14 04:08 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Let us know how many turns the adj takes on the bands if you will,pls.THX!I am not sure but I think you can pump out some extra fluid from the vert by undoing the vert/flex plate bolts and spinning the vert loose or with the starter and the pan off.I am not sure but maybe someone knows.
Re: Auto trans guys, what am I looking at here??....... [Re: Clanton] #1666334
09/02/14 04:11 PM
09/02/14 04:11 PM
Guitar Jones Offline
Just loosen the valve body bolts and pull it down about an 1/8 of an inch. Let it drain, push it back up by hand then tighten the bolts.
