Auto trans guys, what am I looking at here??.......
#1666315
09/01/14 07:15 PM
09/01/14 07:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
.......... besides lots of money 727 behind the 440 in my Barracuda. Has a number of performance upgrades. Pro Trans RMVB, 4 pinion planet, all rollerized, aluminum drum, lightened sun shell, etc., etc.. Noticed this a couple years ago and have not started the car until recently because fluid looked horrible. I did check it often when running it but I think something happened with the last couple street trips. Any guesses?
Re: Auto trans guys, what am I looking at here??.......
[Re: roadhazard]
#1666318
09/01/14 07:20 PM
09/01/14 07:20 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
if it wont stick to a magnet, i say clutch or band material.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: MR_P_BODY]
#1666321
09/01/14 07:47 PM
09/01/14 07:47 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Greg I've seen that before when the fluid pressure dropped and wouldn't hold the clutches. We have to disassemble carefully for proper diagnosis to prevent this from happening again. I'm kinda busy til after Norwalk but I can swing by after that. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Dan Brewer]
#1666324
09/01/14 08:18 PM
09/01/14 08:18 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Aluminum drum on street?? Not a good combo.imo
JAKES AUTOMOTIVE
[Re: Dan Brewer]
#1666325
09/01/14 08:36 PM
09/01/14 08:36 PM
roadhazard
Akron, Ohio U.S.A.
Was it working ok? Check the 2nd gear band adjustment. It looks like aluminum off the drum. How often you change fluid?
I didn't have very many 1/4 mile passes on it (50-75?) and for street miles, not many, I'd assume under 100?
I know the deal with aluminum drum on the street and that's why I regularly checked the fluid. Just one day it was dark so it got parked.
Was working OK the last time out with it on the street. Was also planning a fluid change to keep on top of it.
It just suddenly darkened the fluid, loss of pressure like Gus suggested?
[Re: roadhazard]
#1666328
09/01/14 09:32 PM
09/01/14 09:32 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: dvw]
#1666330
09/02/14 11:44 AM
09/02/14 11:44 AM
Posts: 766 Ohio
Dan Brewer
Ohio
How was it shifting? It looks like normal Aluminum drum mud. I'd clean it out and put a filter in it, see how it goes. If the clutches are burned up your only out the price of fluid and filter. You're not going to kill it any worse. It may be fine. As Jake said aluminum drum on the street is going to create a lot of "aluminum mud". Doug
I agree with Doug. Clean the pan, adjust the band and new fluid. With the aluminum drum you need to change the fluid / filter more often. You also need to use the stock type filter not the brass one.
[Re: Dan Brewer]
#1666331
09/02/14 02:48 PM
09/02/14 02:48 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I do not agree with this because you do not know how what is going on in the trans forsure in my opinion.With that much in the pan I would be concerned.I agree with the stock filter[fiber].Again JMO.
[Re: Clanton]
#1666332
09/02/14 02:59 PM
09/02/14 02:59 PM
roadhazard
Akron, Ohio U.S.A.
Well I'm going to clean the pan, lines and cooler. It had the brass screen filter on it and I'm going to install the fiber filter and some new fluid. As long as it moves that's all I need at the moment. No time for racing in the near future. Thanks for all the input
[Re: Clanton]
#1666334
09/02/14 04:11 PM
09/02/14 04:11 PM
Guitar Jones
Just loosen the valve body bolts and pull it down about an 1/8 of an inch. Let it drain, push it back up by hand then tighten the bolts.
[Re: Guitar Jones]
#1666336
09/03/14 10:22 AM
09/03/14 10:22 AM
roadhazard
Akron, Ohio U.S.A.
Will do sir While I'm in there may as well use a can or two of brake clean to get out what I can.
Any suggestions on band adjustment? What is it.... torque to 73 lb,in then back off how many turns? I'll note the position of the adjuster to start and see if it takes a lot to put back in adjustment.
No coolant in there.... cooler is separate from the radiator.
[Re: roadhazard]
#1666337
09/03/14 10:30 AM
09/03/14 10:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
72 inch lbs.. then back off(this part depends on the VB that you have).. but anywhere between 2 to 2 1/2 turns check with your VB company
[Re: julian2007]
#1666340
09/04/14 03:36 PM
09/04/14 03:36 PM
Posts: 901 oh
julian2007
oh
I was instructed by A&A to adjust the band every 25-30 laps.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
