Converter or Gears?
#166625
12/12/08 07:11 PM
12/12/08 07:11 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
What would be a more effective boost for my situation? The motor is a 318, .477/.480 lift cam, stock compression pistons, headers, 904, stock converter, 3.21 non sure grip 8 1/4. I want to get the tires to break free a bit easier and pull a bit harder in second gear. Should I go with a 2000-2200 stall tc, or just up the ratio in the 8 1/4 to a 3.55 or 3.73 with a sure grip? I pull 16-18 mpg at 65 on the hwy now and would like to retain as much as possible, as well as getting my ets down to the solidly in the mid to high 14s. So far, my best is 15.02.
The tire is a 235/70/15 and it currently turns 2750 at 65 and 3000 at 75.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Converter or Gears?
[Re: MoparJ]
#166627
12/12/08 07:51 PM
12/12/08 07:51 PM
Posts: 571 Western NC
68Bullit
Western NC
Check out the convertors from Mopar Performance too. They don't cost a fortune, and are perhaps the best milder performance convertors for the money. I have a 904 behind my mild 360 and I'd have to look up the number, but the one that I have is the highest stall they offer (around 2200-2500), and very streetable. Also, I agree on going with the convertor instead of gears to retain better mileage.
[Re: MoparJ]
#166631
12/13/08 08:41 PM
12/13/08 08:41 PM
Posts: 25,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A stock 904 converter behind a 318 should stall in the range the OP desires.
Changing to as higher stall converter with low numeric gear ratios can result in the converter slipping at medium road speeds.
IMHO, the 3.55/3.73 gear change would be wiser than a converter change.
